columbia107
Axalp Questions
Thu Aug 30, 2007 12:38 am
Now that I have made all my travel and accommodation arrangements for my first ever attendance at Axalp, its time to prepare the equipment.
Can someone advise me on what type of lens I should equip my camera's with. Nikon 70/200mm or Nikon 200/400mm.
I also believe that there are three prime locations - Brau, Tschingel and Ebenfluth - from where one can watch the proceedings. Anyone has any thought as to which is the best location, taking into consideration the aircraft flight path?
I am also led to understand that most of the shooting tends to be challenging due to the aircraft's high speed, difficult light conditions as well as back-light. Anyone has any suggestions on camera settings, etc.?
Look forward to reading your comments. Thanks
In God we trust
timdegroot
RE: Axalp Questions
Thu Aug 30, 2007 12:46 am
Quoting Columbia107 (Thread starter):
I would bring both but if you can bring one take the 400, you need it.
The 2 hills nearest to the target are both excellent, visit them both. first hill is not good.
Very difficult indeed. You won't really know settings until you're there as the weather can vary quite a bit. You need to maintain fairly high shutterspeeds though and hence need high ISO settings (at least 200, 400 works better)
Tim
Alderman Exit
ThierryD
Crew
RE: Axalp Questions
Thu Aug 30, 2007 1:09 am
Quoting TimdeGroot (Reply 1):
 checkmark
And as Tim said, high shutterspeeds are a must for the jets but since there will also be some chopper displays you'll want to switch to slower shutter speeds for those.
Regardless of the photo equipment also prepare yourself well regarding warm clothing, good shoes, catering and stamina. You'll need all this if you want to fully enjoy the show!
Thierry
"Go ahead...make my day"
columbia107
RE: Axalp Questions
Thu Aug 30, 2007 2:32 am
Thanks Tim/ Thierry for your useful comments.
In God we trust
walter2222
RE: Axalp Questions
Thu Aug 30, 2007 8:31 pm
Hi,
Here is a link to a photo-page from the Swiss Air Force website:
http://www.lw.admin.ch/internet/luft...e/de/home/pictures/axalp_2006.html
There are some shots - taken from a heli - showing the third location. This gives you an idea what to expect.
This map might also be handy:
http://walter2219.fotopic.net/p22780914.html
Have fun at Axalp!
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
javibi
RE: Axalp Questions
Fri Aug 31, 2007 7:28 pm
Quoting ThierryD (Reply 2):
I knew I was doing something wrong...
j
ThierryD
Crew
RE: Axalp Questions
Fri Aug 31, 2007 7:58 pm
Quoting Javibi (Reply 5):
No, Javier 1/40s is perfectly fine for panning shots; only your 200 tries for 1 good photo is difficult to achieve at Axalp!  Big grin  duck
Thierry
javibi
RE: Axalp Questions
Fri Aug 31, 2007 8:10 pm
Quoting ThierryD (Reply 6):
I wish it was that easy...  Smile
j
