Domjan
Level Rejection Help
Thu Aug 30, 2007 6:26 am
I've got this rejected for "level" -- and I am a bit clueless. I leveled on the terminal horizontals...
The tower's left side could get a bit of CCW, though...
What's your opinion?
http://www.airliners.net/addphotos/rejections/big/20070829_070826_HB-IHS_LSZH_HD_42.jpg
Many thanks!
timdegroot
RE: Level Rejection Help
Thu Aug 30, 2007 6:35 am
Needs a bit of ccw
Tim
Alderman Exit
EK20
Thu Aug 30, 2007 6:38 am
Quoting TimdeGroot (Reply 1):
Needs a bit of ccw
About 0.5 and also reducing it to 1024 pixels will improve it as well.  Smile
Lanas
Thu Aug 30, 2007 6:46 am
It´s indeed unlevel, needing some CCW rotation, as you say, because...
Quoting Domjan (Thread starter):
...you should always use vertical lines as a reference, if possible.  checkmark
If it helps, I see your shot a bit too bright and soft. Maybe you could compensate that in order to help increase the picture´s chances.
Good luck with it.  Smile
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
Domjan
Mon Sep 03, 2007 11:08 pm
Submitted that one -- still "level".
Probably I overdid the CCW? The pic looks indeed somehow odd, yet the tower is now perfectly vertical... Smile
Any suggestions?
http://www.airliners.net/addphotos/rejections/big/20070903_070826_HB-IHS_LSZH_HD_42_2.jpg
EK20
Tue Sep 04, 2007 12:41 am
Quoting Domjan (Reply 4):
Any suggestions?
Needs about 0.2/0.3 CW I think.
Lanas
Tue Sep 04, 2007 5:09 am
Quoting EK20 (Reply 5):
Yes, I agree.  checkmark
Sometimes you need to check on the overall look of the image, to assure it´s level. It´s strange here because the tower appears to be vertical, but with a couple of notches of CW rotation I think it will be better.
Lanas.-
Domjan
Sun Sep 09, 2007 2:21 am
Dear all,
rotating my first attempt by .5 CCW was actually the same as rotating my second attempt by .3 CW...and voila, it got accepted :
Photo © Hans Domjan
Many thanks for your suggestions!
Hans
[Edited 2007-09-08 19:23:18]
