walter2222
I Should Have Known Better...
Fri Aug 31, 2007 5:06 am
While browsing the database and reviewing the shots of the Belgian Air Component's twin stick F-16B (reg: FB-18) with the "20 years OCU" anniversary scheme, I was wondering why nobody had uploaded a close-up of this magnificent tail?
Now, I found out: I uploaded a close-up - since I thought it was a nice addition to the database - but... it was rejected for double:
http://www.airliners.net/addphotos/r...070717_CRW_9047_RT8_WVB_1200px.jpg
I am not complaining, because the rule is clear (it is from the same sequence - on the ground/static) and it the shot is taken from the same side (only slightly different)...but it is good to know for other photographers who have not yet uploaded a side shot...
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
JRadier
RE: I Should Have Known Better...
Fri Aug 31, 2007 7:48 am
Quoting Walter2222 (Thread starter):
don't worry, some get old faster than others
[Edited 2007-08-31 01:06:16]
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
JRadier
Fri Aug 31, 2007 8:06 am
Quoting AirKas1 (Reply 2):
Ditto Wink
what?  Wink
walter2222
Fri Aug 31, 2007 5:12 pm
Quoting JRadier (Reply 1):
 rotfl   rotfl
...but never too old to learn!  Smile
Walter
walter2222
Mon Sep 03, 2007 3:22 am
Now that I finally thought I understood the rule about double, I deleted the other tail close-up I had in the queue (FA-101), since I had already another shot (+/- 45 degrees-frontal) from the same aircraft/day accepted.
While browsing through my other recently accepted shots, I discovered that these two - "double"-seaters - were also accepted, within a period of a week, without rejection for double...
Photo © Walter Van Bel
and
So, was one of these wrongly accepted?
Thanks for further inputs!
Walter
ThierryD
Crew
Tue Sep 04, 2007 6:35 am
Quoting Walter2222 (Reply 4):
Hi Walter!
According to the double rule you get only 1 shot per sequence (in this case: parking) accepted for same a/c, same airport, same date.
So the Eurofighter most probably got through by error; normally you would only have gotten either the full view OR tailshot accepted especially since the aircraft is already pictured many times in the db.
The luck was with you on that one.  Wink
Thierry
"Go ahead...make my day"
walter2222
Tue Sep 04, 2007 6:59 am
Quoting ThierryD (Reply 5):
Thanks for the feedback, Thierry!
By coincidence, I was reading a very old post (from 2006) of mine about a motiv rejection. At that time there was also a discussion about the double rule and at that time it was stated that the rule was there to prevent photos entering the database that looked "similar" (when taken by same photographer on same day, same location, same motive,...), but that it would - generally - not be a problem if the 2 photo's would each have a complete different motiv...(e.g. a tail-shot and a nose close-up). Could it be that this is the interpretation that is used? Just a thought...
PS: As an ex aircraft model builder, I have some interest in close-up shots of aircraft. The detail of the tail-shots is not available in the 45degrees/front shots, so that's what I thought of being different enough...
I think it is worth further discussion! What are your thoughts about this? Just trying to clarify the double-issue a bit more. If we hereby come to a more clear rule, all the better (if one of my doubles has to leave, I have no problem with that if it saves us and the screeners some time in the future).
Walter
Users browsing this forum: KTMVT2 and 1 guest
