stefan171288
Two Bad Info Rejections
Thu Sep 06, 2007 8:52 pm
Hi,
I had these two shots rejected for info.
http://www.airliners.net/procphotos/...filename=20070906_EPV022322378.jpg
http://www.airliners.net/procphotos/...main?filename=20070906_EPV0008.jpg
Should it be Untitled (FIS Air Service)?
Is the 2nd one ok as nose?
Stefan
boeingfreak
RE: Two Bad Info Rejections
Thu Sep 06, 2007 9:25 pm
Hi,
I think you should have typed in Untitled (FIS Air Service) as there are no titles on the aircraft that reveal the operator. Should work for both shots, the second one isn't a typical "category-nose" shot.
Florian
ptrjong
Thu Sep 06, 2007 10:14 pm
Quoting Boeingfreak (Reply 1):
Maybe you're right, but it does show only the nose, doesn't it?
On the other hand, NOSE is only for airliners. This aircrraft is AIRLINER OR OTHER in the first row and the operator is an AIRLINE, but does that make a small turboprop an airliner? These categories...  scratchchin
Peter Smile
