carlos
Crew
Overexposed - Two Rejections?
Sat Sep 22, 2007 7:52 pm
Hi,
these two pictures were rejected today with the reason "OVEREXPOSED".
I checked both pictures with CS 2 and in my eyes both pictures are okay.
http://www.airliners.net/addphotos/r...ons/big/20070922_ZS-SNH_1407jp.jpg
http://www.airliners.net/addphotos/r...ons/big/20070922_N807NW_0405jp.jpg
What do you think? Whats the problem?
Thanks a lot
Klaus
NIKV69
RE: Overexposed - Two Rejections?
Sat Sep 22, 2007 10:48 pm
SA fuselage looks a little overexposed but the NW looks ok to me. Though the back of the NW fuselage is maybe a little.
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
martin54
Sun Sep 23, 2007 12:35 am
On my LCD screen both look indeed a little bit overexposed, the SA worse than the NWA.
codeshare
Sun Sep 23, 2007 12:47 am
NW needs a little underexposure, while the SAA needs way more. Play around with Curves or Levels.
KS/codeshare
How much A is there is Airliners Net ? 0 or nothing ?
G-CIVP
Sun Sep 23, 2007 6:42 am
As an aside, the fence in the bottom of the frame with the SAA A340 is rather distracting.
carlos
Crew
Sun Sep 23, 2007 4:36 pm
Hi,
this ist the Histogramm of the SAA.
http://www.airliners.net/uf/536908993/119053273863nY54.jpg
I can't find any areas with pure white (255,255,255) which are blown out. So I don't know what to do.
Does anybody has an idea?
Klaus
dendrobatid
Sun Sep 23, 2007 5:03 pm
Klaus
Let me start by saying that neither of the images are far off being correct.
The SAA is too bright to my eyes despite what the histogram shows and I would use the level to tone that one down a bit, probably about 0.90 on the centre slider (ie not much)
The NW is even closer to the mark and the only bit that is even close to overexposed is the highlight on the fuselage but darkening would render the shadows too dark.
If I was you I would tone the SAA one down a bit and resubmit and see what the HS think of the NW by an appeal
Mick Bajcar
carlos
Crew
Sun Sep 23, 2007 5:36 pm
Hi Mick,
thanks a lot for your useful comment.
So I'll appeal the NW. I edited the SAA and here is the result:
http://www.airliners.net/uf/536908993/1190536493HF6FoN.jpg
Does it look better now?
dendrobatid
Sun Sep 23, 2007 5:53 pm
Quoting Carlos (Reply 7):
Look at the top of the fuselage and there is detail held into the white where it was just gone before so, yes it looks better.
The change is subtle but enough to bring it to (more than) acceptable
Mick
