MAN23R
Shots From MAN?
Fri Oct 12, 2007 6:02 pm
Afternoon,
could these get accepted?or how i could edit to get accepted...
some nice angles....
http://www.airliners.net/uf/view.fil...0863&filename=11922116470JVy31.jpg
http://www.airliners.net/uf/view.fil...0863&filename=1192211433NGCvPH.jpg
somethings happening with this site stuggling to to upload photos, will add more when i can...
scott
scott
jamesbuk
RE: Shots From MAN?
Fri Oct 12, 2007 6:10 pm
Quoting MAN23R (Thread starter):
http://www.airliners.net/uf/view.fil...1.jpg
The KLM tail kills it for me as it blocks the thomson plane.
You cut of the rear bit of the elevator - not sure if thats the original but if thats been cropped then IMO that should be in.
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
MAN23R
RE: Shots From MAN?
Fri Oct 12, 2007 6:29 pm
G-CIVP
RE: Shots From MAN?
Fri Oct 12, 2007 8:23 pm
The KLM on stand is one for the personal collection! Too much ramp activity and the light pole blocks the tail.
oly720man
RE: Shots From MAN?
Fri Oct 12, 2007 11:06 pm
In reverse order
Quoting MAN23R (Reply 3):
myt 767 http://www.airliners.net/uf/view.fil...w.jpg
Elevator clipped. Looks too yellow to me. Compare the grass and taxiway with this one.
bmi a330 http://www.airliners.net/uf/view.fil...k.jpg
Elevator clipped.
a great line up http://www.airliners.net/uf/view.fil...f.jpg
Too much in front of the Delta 764
tcx a320 and man http://www.airliners.net/uf/view.fil...5.jpg
Man in focus (and blocking plane), plane not. Dirt above and right of fin and above/right of red hat.
Quoting MAN23R (Reply 2):
BA 737 http://www.airliners.net/uf/view.fil...8.jpg
Not level. Needs a bit of anticlocwise rotation - check against MyTravel hangar doors behind plane.
FCA A320 http://www.airliners.net/uf/view.fil...H.jpg
Dirt or bird? Top right and above 't' in First Choice. Faint dirt above 2nd fuselage bump in line with black spot above 't'. Sky looks grainy in parts - compression artefacts or editing?
ryanair 737 http://www.airliners.net/uf/view.fil...v.jpg
Slightly yellow, soft.
virgin 747 http://www.airliners.net/uf/view.fil...c.jpg
Yellow cast. Crop could be closer to tail to match with nose? Slight clockwise rotation needed.
ilikeflight
RE: Shots From MAN?
Fri Oct 12, 2007 11:08 pm
They all suffer from quality issues
Think Different
MAN23R
RE: Shots From MAN?
Sat Oct 13, 2007 8:34 am
morning guys,
ive updated them slightly,just sharpening the aircraft, sky doesnt look that grainly now.
ill try to edit the ones what could get in.
please bear in mind although its taken with a canon 400D im still using the stock lense (18+55), going to upgrade soon, what lense would you guys recommend 70-300?
scott
[Edited 2007-10-13 01:45:15]
Users browsing this forum: Baidu [Spider] and 1 guest
