graphic
Quick Question
Wed Oct 17, 2007 8:33 pm
http://www.airliners.net/addphotos/r...g/20071017_N453NDshortfinalGFK.jpg
I'll fix the "dark," but as for the "level" I thought it was ok to use the aircraft as the reference to level, where in this case the panel appears horizontally level in the frame. Has anything changed with that or was I mistaken?
Demand Media fails at life
ilikeflight
RE: Quick Question
Wed Oct 17, 2007 8:36 pm
Needs a little bit of CCW rotation
Think Different
ThierryD
Crew
RE: Quick Question
Wed Oct 17, 2007 8:41 pm
Quoting Graphic (Thread starter):
Eric, in this case the outside, clearly visible, horizon is the reference to go for!
Thierry
"Go ahead...make my day"
aviopic
RE: Quick Question
Wed Oct 17, 2007 8:47 pm
I am not sure whether there is a strict rule.
In your case though I would have kept the horizon as a reference because it is visible and just slightly off.
However if there is no way to correct the horizon due to a severe bank I do switch to the glare shield as reference.
Photo © Willem Honders
The truth lives in one’s mind, it doesn’t really exist
timdegroot
RE: Quick Question
Wed Oct 17, 2007 9:11 pm
We allow unlevel horizons but only if it's a steep bank like in Willem's shot
Tim
Alderman Exit
JRadier
RE: Quick Question
Wed Oct 17, 2007 9:20 pm
seems pretty grainy to me as well, might be something to look into.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
graphic
RE: Quick Question
Sat Oct 27, 2007 5:17 am
How's this?
Users browsing this forum: spompert and 1 guest
