Ander
Spotting In Kbos
Tue Oct 30, 2007 10:08 pm
Hi all,
Looking for some advice regarding photography around KBOS.
I'll be flying sunday and I have monday morning to spare, so I'll
be very greatful if anybody can give me some advice on spots,
public transportation, security and so on.
Thanks in advance,
Ander
Born to tri.
ake0404ar
RE: Spotting In Kbos
Wed Oct 31, 2007 2:01 pm
Ander,
do a search for Boston in the AV forum and lot's of info will come up.
Vasco
dvincent
Wed Oct 31, 2007 8:15 pm
Three areas of interest...
1. If the 22s are in use, constitution beach. Get off at the Orient Heights or Woods Hole station on the blue line at the T and walk down bennington St until you get to the beach overpass. Need at least a 70-300 if you want to get anything smaller than the big heavies.
2. Castle island in south Boston. You need a car for this.
Both of these spots are useless in the morning, the sun is in the wrong position and you can only use them if the 4s/22s are in use.
If rwy 27 is in use there's a park in Winthrop that I like to spot at and it's good through the day. Never tried in the morning though.
If the 33/32 are in use, you are out of luck, unless you have a boat  Wink ... unless you want to try the parking garage, and then you're at risk of being tossed by Massport.
From the Mind of Minolta
ake0404ar
Thu Nov 01, 2007 8:49 pm
Quoting Dvincent (Reply 2):
If the lens is long enough, RWY 33L is doable ........
Photo © Vasco Garcia
Vasco
Ander
Fri Nov 02, 2007 11:24 pm
Thanks a lot both of you.
Not sure if I'll go finally as I don't have a car and not sure about possibilities with
such a short time. But I appreciate your help anyway.
Ander
Born to tri.
