sluger020889
Nikon Lens Calibration
Sun Nov 04, 2007 11:41 pm
After comparing with a fellow photographer with the same lens, I've come to the conclusion that my 80-400 VR needs to be calibrated. The reason being softness out at the longer focal lengths. Now I know the 80-400 isn't tack sharp out at 400, but shots taken in the f8 to f10 range, and shutter speeds 1/500 and greater, shouldn't be completely useless. Not to mention I'm noticing parts of the image in the left bottom side of the frame are soft and often times blurry. I also know it's not the camera body because I recall having similar issues on my D50.
So how do I go about getting my lens calibrated?
Joey
I would love to fly a cargo plane full of rubber dog shit out of Hong Kong!
NIKV69
RE: Nikon Lens Calibration
Sun Nov 04, 2007 11:49 pm
I would first diagnose the problem first and make sure that you have no other problems with the lens. Also I would let nobody but Nikon touch it.
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
CalgaryBill
Mon Nov 05, 2007 12:39 am
Agreed with NIKV69 - send it to Nikon and don't let anyone else mess with it. Unless you are 100% certain the body isn't part of the problem, I'd send the lens and camera together.
If the focus is asymetrical it could be a lens element is out of alignment.
B
sluger020889
Mon Nov 05, 2007 1:29 am
Well I've been having softness/focusing issues on two bodies, the D50 and the D200. Both of which my settings were between f8 and f10 with shutter speeds at or above 1/500th. Some where on the verge of being oof.
Here is my shot, taken with my D200, set to Dynamic AF, center point selected, 400 mm, f9, 1/500, ISO 160
http://img510.imageshack.us/img510/7338/sas0103ex1bn0.jpg
http://img510.imageshack.us/img510/7338/sas0103ex1bn0.c3ee81436e.jpg
And my buddies shot (with permission) D70, 400mm, f8, 1/640
http://img391.imageshack.us/img391/6420/sas0103ex2cv5.jpg
NIKV69
Mon Nov 05, 2007 2:36 am
Quoting CalgaryBill (Reply 2):
I wouldn't send the body, Nikon has probably a million test bodies in the shop.
I was thinking the same thing.
CalgaryBill
Mon Nov 05, 2007 3:07 am
Quoting NIKV69 (Reply 4):
I only suggested that in case it was a calibration issue, which is adjusted in the body. But if it's happening equally on multiple bodies, then it's likely only the lens...
B
Users browsing this forum: No registered users and 4 guests
