cpd
My First Time In Honolulu - 1 Photo, Advice Needed
Thu Nov 15, 2007 12:34 pm
I ended up in Honolulu by accident on a United Airlines 870 flight that did a emergency landing in PHNL with an engine oil pressure problem. After a 6 hour delay, this 767 arrived to get us to KSFO. It had technical dramas as well. Despite all that, the crew on the plane looked after everyone very well.
I took that photo. Since I do still have the RAW file, should I do any more editing to this before attempting to put it in the queue? Should I rotate it CW to level the taxy-way, or should I leave it as is and have the building in the background level (vertical lines)?
I'm also going to try putting this one in the queue:
http://www.airliners.net/addphotos/big/ready/ups_n287up_071103.jpg
That MD11F did the first go-around I've seen. Either it came in too quickly, or the BA 777 on the runway was too slow in getting away. I never realised just how noisy and smoky an MD11 could be.
[Edited 2007-11-15 04:38:49]
eadster
RE: My First Time In Honolulu - 1 Photo, Advice Needed
Thu Nov 15, 2007 1:25 pm
Hey my advice would be to forget about the UA shot. Ramp clutter is in the way so its a no go.
UPS looks quite good. Check the histogram, it looks under exposed to me.
ilikeflight
Thu Nov 15, 2007 3:12 pm
The UA sht would get a motive
The UPS shot id a little dark lighten it up and you should be good to go
Think Different
cpd
Thu Nov 15, 2007 7:26 pm
Thanks for the advice - but the UPS one is representative of the brightness on that day.
What I might do is leave it for the moment, see what it gets, and if it does get flagged for exposure, I'll see what I can do about it. I tried adjusting the exposure a little bit and it loses detail when I do it.
I could try this in place of the UA one:
http://www.airliners.net/addphotos/big/ready/cathay_a330_blaf-syd.jpg
I also have a Singapore 747 that might be worth it:
Big version: Width: 1280 Height: 1023 File size: 447kb
Silver1SWA
Crew
Thu Nov 15, 2007 8:21 pm
Quoting Eadster (Reply 1):
You know, I hate to say it but...I wouldn't be surprised if it got a motiv rejection because of the small sign in front of the main landing gear.
eadster
Fri Nov 16, 2007 12:30 am
Quoting Silver1SWA (Reply 4):
Doesn't matter - its under exposed.
Well, i don't think it would. Its not all that big. Could be wrong though.
Other two look good - I'd be checking the exposure of both just to be sure, but I'd also check the colour balance on the Cathay shot. Look a little off at first glance.
cpd
Fri Nov 16, 2007 7:29 am
I think my screen might have something to do with it as well on the exposure stuff, I've got the Apple A1081 which is very bright. I might run the Spyder on it just to be certain.
Thanks for all the advice!  Smile
I could probably do something about that sign on the MD11, but that'd be sneaky..  Wink
eadster
Sat Nov 17, 2007 12:50 pm
Quoting Cpd (Reply 6):
You can't now because you mentioned it!!!!!!!
cpd
Sun Nov 18, 2007 5:48 am
Both the UPS MD11 and the Cathay B-LAF got through.  Smile
I'm happy.  Smile
