whisperjet
Crew
Spotting In Miami
Thu Nov 22, 2007 6:27 pm
Hi,
a friend is planning to go to Miami on a spotting trip. As he hasn't got a driving license, he'd like to know if it's possible to get to the spotting positions without a car (walk or public transportation).
Thanks in his name
Stefan
Nobody is perfect - not even a perfect fool.
miamiair
RE: Spotting In Miami
Mon Nov 26, 2007 2:11 pm
He better bring some walking shoes. Most of the spotting locations are on the west side of the airport. The "Holes" is the farthest from any semblence of public transport. A taxi can get you there, but taxis in MIA are not cheap. It may help to know where he will be staying. There are a couple of hotels within walking disatnce of the Holes as well as the spot at the approach end of runway 09.
mattbna
Tue Nov 27, 2007 12:04 am
Quoting Miamiair (Reply 1):
Why would he need the photography fence holes for spotting? Spotting involves using a notepad / logbook and binoculars to write down tail numbers.
Matt
Canon EOS 7D & 40D -- 100-400mm L IS -- 70-200mm f/2.8L IS II -- 28-135mm IS -- 10-22mm -- 18-55mm EF-S
miamiair
Tue Nov 27, 2007 11:55 am
Quoting Mattbna (Reply 2):
Because that is where the police will not give you any grief. From there you get the departures on 08L/08R and 12 as well as the arrivals.
Unless he wants to sit in a parking lot away from the airport, then he will miss out on the departures.
mattbna
Tue Nov 27, 2007 5:26 pm
Quoting Miamiair (Reply 3):
Ok...You completely missed the point of what I said.  Smile
I know why he would want to take photos from the fence holes - that is obvious. I was pointing out that a 'spotter' wouldn't need the photo holes as 'spotters' use binoculars, etc. to write registration numbers down in a log book.
The original e-mail said that someone was going on a "spotting trip" and the reply suggested using the photo holes - which would be pointless for a 'spotter'...  Smile
Matt
miamiair
Tue Nov 27, 2007 5:55 pm
Quoting Mattbna (Reply 4):
Matt,
The "holes" is the area where one can go and observe/spot/photograph aircraft and numerous people spot from there. Not necessarily use the holes in the fence.
I think not.
visityyj
Tue Nov 27, 2007 8:46 pm
No. There is a bus route from the MIA terminal which goes round the S. and E sides of the airport. The holes are on 25th Street, about 5 minutes walk from Milam Dairy (72nd Ave) http://www.co.miami-dade.fl.us/transit/images/pdfs/routes/238.pdf . Only runs once an hour though.
There has always been confusion on this site over the term 'spotter'. It's used interchangeably (by some) to mean either a number-logger and/or a photographer. Not clear which OP meant.
hth
mattbna
Tue Nov 27, 2007 9:17 pm
Quoting Visityyj (Reply 6):
...which is precisely the problem.  Smile
This younger generation of photogs are calling themselves 'spotters' and they have no idea what a spotter really is / does.
Matt
