RCoulter
Too Much Contrast?
Fri Nov 23, 2007 4:55 pm
Big version: Width: 1280 Height: 960 File size: 850kb
I also am going to make a few more small edits to it, but my main worry is that it may get rejected for contrast. I am hoping it would make it though since this is a rare plane especially for RNO.
boeingfreak
RE: Too Much Contrast?
Fri Nov 23, 2007 5:05 pm
Hi, contrast isn't your main problem, your picture is highly overexposed, a real shame because it would be a great photo! If you shot in RAW there might be a small chance to save it, though.
Hope this helps,
Florian
DM
Fri Nov 23, 2007 5:06 pm
Seems overexposed and uncentered. Contrast looks ok to me.
DM
RCoulter
Fri Nov 23, 2007 5:21 pm
Ok, here it is re-cropped a bit and I think I may have fixed the over-exposure.
One more for good measure:
Big version: Width: 1600 Height: 1200 File size: 598kb
[Edited 2007-11-23 09:42:36]
KLM772ER
Fri Nov 23, 2007 5:43 pm
Quoting RCoulter (Reply 3):
It is still way to overexposed.. I don't think you can save it at least not if the original is the sameway overexposed.. Did you shoot in RAW?
Bjorn
Edit: The second version is much better! (It wasn't there when I posted  Wink )
[Edited 2007-11-23 09:54:39]
RCoulter
Fri Nov 23, 2007 5:53 pm
Quoting KLM772ER (Reply 4):
Bjorn
Bjorn,
The original for the top one is a little overexposed but not by much. I did shoot in RAW and in the programs I use to edit the RAW files I didn't have to use much highlight recovery. The last one I posted is not overexposed at all according to those programs either (using the highlight alert). Let me try editing the top one again.
[Edited 2007-11-23 10:01:17]
DM
Fri Nov 23, 2007 5:58 pm
It played with it a little and tried to make it less overexposed.
Big version: Width: 1280 Height: 960 File size: 950kb
Ryan Coulter
DM
RCoulter
Fri Nov 23, 2007 6:03 pm
Here is a new edit:
1600px:
1280px:
Also, which crop looks the best? I have one where the whole plane is in the frame, but I think it looks weird. I also kind of like the 2nd one in Reply #3.
[Edited 2007-11-23 10:05:47]
[Edited 2007-11-23 10:06:07]
Psych
Fri Nov 23, 2007 6:21 pm
Hello Ryan.
I agree the early edits looked much too bright. Things are improving with further edits - for me it is the tail area that needs to have a little bit of detail. In the first edit it was pretty blown out.
As regards cropping - your edits here show an issue often discussed: tailplanes right up against the crop at the top with space below the wheels (as in #2, Reply 3). I much prefer a shot that looks more balanced. For example, in the shots above, the plane still looks to me to be placed too much in the higher right portion of the image, if you see what I mean. I think you need to crop closer there on the left and also get rid of a lot of the 'dead' tarmac below.
All in all I think I prefer #2, Reply 3, if the plane was more vertically centred.
Cheers.
Paul
RCoulter
Fri Nov 23, 2007 6:24 pm
Quoting Psych (Reply 8):
Hello Ryan.
Cheers.
Paul
Yea, I wasn't sure how to center shots like these, thanks for the advice, let me try some things and see what I can come up with  Smile
RCoulter
Fri Nov 23, 2007 6:31 pm
New edit:
Just for kicks, one with a bit more of the taxiway sign:
Big version: Width: 1280 Height: 960 File size: 974kb
[Edited 2007-11-23 10:33:19]
KLM772ER
Fri Nov 23, 2007 6:52 pm
I like the first one of reply 10 best regarding contrast and centering!
But I think it needs a little CCW Rotation and is a little oversharpened.. (for example the end of the tail, the blue stripe, nd a little bit on the top of the fuselage!
bjorn
RCoulter
Fri Nov 23, 2007 7:00 pm
Quoting KLM772ER (Reply 11):
bjorn
Big version: Width: 1280 Height: 960 File size: 916kb
Like that?
KLM772ER
Fri Nov 23, 2007 7:34 pm
Maybe a tad too much Rotation, the sharpening is better!
Good luck with it!!
Bjorn
RCoulter
Fri Nov 23, 2007 7:42 pm
Quoting KLM772ER (Reply 13):
Good luck with it!!
Bjorn
Yea, it definitely is a tough one to level.
Alright here is the one I put in the Q:
http://www.airliners.net/addphotos/big/ready/ZD948_T16R-11.jpg
DeltaAVL
Fri Nov 23, 2007 7:45 pm
Quoting RCoulter (Reply 14):
I think you're good to go with this one. Great shot!
"We break, We bend, With hand in hand, When hope is gone, Just hang on." -Guster
RCoulter
Fri Nov 23, 2007 7:48 pm
Thanks for all the help guys! It's up to the screeners now Big grin
RCoulter
Sat Nov 24, 2007 5:49 pm
I also have one more I need help with, does this look centered or is it a little high?
http://www.airliners.net/addphotos/big/ready/7162007_925AU.jpg
TIA
RCoulter
Tue Nov 27, 2007 8:33 pm
It made it! Thanks for all the help guys!
Photo © Ryan Coulter - MachImages
