ac888yow
Do The Screeners Have Their New Monitors?
Tue Nov 27, 2007 2:17 pm
Have the new monitors been deployed across the screening team yet? If so, I can't help but feel that there is an issue with the evaluation of photo sharpness since I recently had a bunch of 'soft' rejections. I say this because I have been using the same sharpening method for over a year without a single 'soft' rejection in that time, and all of a sudden I am getting 'soft' rejections.
Here's some examples, all rejected for soft:
http://www.airliners.net/addphotos/r..._8407_ZM_CGTSN_092007_CYOW_752.jpg
http://www.airliners.net/addphotos/r...483_AC_CFXCA_092007_CYOW_763_2.jpg
http://www.airliners.net/addphotos/r...284_AC_CFITW_111207_CYUL_773_3.jpg
acontador
RE: Do The Screeners Have Their New Monitors?
Tue Nov 27, 2007 2:24 pm
Hi Peter,
If you look closely at the Zoom one, you'll see that the camera focused on the terminal behind, so the aircraft itself is out of focus and thus appears very soft.
I think on the AC ones, they were also rejected for other reasons...but even so, they are slightly soft, lacking the very last 'kick' in sharpness.
Hope it helps, and keep'm coming  Smile !
Just sit back, relax and have a glass of Merlot...enjoy your life!
ac888yow
Tue Nov 27, 2007 2:36 pm
Thanks for your information.
On the Zoom shot it's impossible for the camera to have focused anywhere but on the plane since I have configured my camera to focus using the center point only. Unless it has somehow developed x-ray focusing without me knowing.
As for the other shots, again, I've done nothing to change my sharpening method so quite clearly what has been working for more than a year is no longer working. Based on this I can only conclude that the sharpening standard has been quietly elevated by the screeners.
shep2
Tue Nov 27, 2007 2:41 pm
Peter -
All the shots above look sharp enough to me. Having said that, I think I'll delete the few I have in the queue - because softness looks to be a confusing thing here lately...
[Edited 2007-11-27 06:43:22]
acontador
Tue Nov 27, 2007 2:59 pm
Hi Peter,
If you don't agree with the screening, you can always use the appeal function. We try our best, but we are also human and thus can make mistakes. And please, when you post rejections, indicate all rejection reasons.
I really like the AC shots, so I hope you'll rework and reupload them!
ac888yow
Tue Nov 27, 2007 3:02 pm
Quoting Shep2 (Reply 3):
Peter -
They are sharp enough based on my experience on what has been the standard for more than a year. You're not seeing things.
As I said, the only explanation is that the sharpening standard has been quietly elevated. Sadly, no member of the crew is willing to confirm or refute this.
I'll adapt and add more sharpening in the future. Then I'll sit by unsurprised when the oversharpened rejections start to fly.
KMB
Tue Nov 27, 2007 3:25 pm
AC888YOW This is most likely down to pixel density.
17" monitors are usually 1280x1024 so are 19" so with a larger area images on a 19" will look softer than they do on a 17"
Consequently with widescreen
20.5" standard is 1680x1050 so are 22" (Used by screeners I think) so again with a larger area images on a 22" will look softer than they do on a 20.5" screen.
Its all about pixel density or dot pitch.
Hope that helps.
Better to ask a stupid question than make a stupid mistake.
bubbles
Screener
Tue Nov 27, 2007 3:29 pm
Quoting AC888YOW (Reply 5):
Hi Peter
I don't think our sharpening criterion has been changed.
Zoom: The plane looks soft/blurry in parts, such as, nose and tailfin.
Air Canada B767: The major problem is that shot was underexposed.
Air Canada B777: The nose and tailfin are out of focus due to depth of field.
Hope this helps!
_Hongyin_
ac888yow
Tue Nov 27, 2007 4:13 pm
Quoting KMB (Reply 6):
Hope that helps.
It does. I think this is exactly what's happening. So I'll adapt and add more sharpening in the future to compensate for this.
Quoting Acontador (Reply 4):
I don't agree with the screening, but don't mistake my questions as typical screener hate that is so often posted around here. All I asked was why a method that has worked for me for a long time is no longer working. I'm confident KMB's response is the reason.
Maybe, but I don't think so. I know the work and attention to detail I put into my pictures and editing, so I firmly believe each and every picture I upload is good enough (unless I do something totally silly like level incorrectly or submit borders or something). This is why I have a fairly strict 'one strike you're out' (where 'you' is a.net) policy where I don't re-work or re-upload rejections. I've gone against it in the past for shots that are really important (or if I'm in an excessively good mood), but in most cases it's a matter of principle. Admittedly it's a bit of a stubbornness thing as well.
Quoting Bubbles (Reply 7):
Hope this helps!
_Hongyin_
Duly noted. Thanks Hongyin.
