walter2222
Will This Result In A Double Reject?
Wed Dec 12, 2007 8:36 am
Hi there,
I had put this one in the queue, I liked the light conditions (although backlit), but I only realised that I had a similar one (same serial, same day) already in the database:
in the queue:
http://www.airliners.net/addphotos/b...n_20051011_IMG_2798_WVB_1200px.jpg
this one already in the database:
Photo © Walter Van Bel
I know both shots are showing the helicopter from roughly the same side, but attitude is different. So, my question, is it different enough to avoid double rejection or should I pull it?
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
dendrobatid
RE: Will This Result In A Double Reject?
Wed Dec 12, 2007 9:38 am
Walter
I feel that they are too similar and there is a very strong risk of a double rejection. The level looks way off to me on the queued image too....look at the pole of the windsock
Mick Bajcar
walter2222
Wed Dec 12, 2007 11:40 am
Hi Mick,
Thanks for the feedback! I will pull it then before it gets screened (still a couple of days to go  Wink , so I can still leave it here for anyone to read this thread...).
PS: I agree, that the level looks odd, because of the pole with the windsock (which is not a perfect vertical...), but I aligned it with some other verticals on the part of the picture that is now cropped out...
Walter
Lanas
Wed Dec 12, 2007 12:49 pm
Hi Walter
The angle is not that different, so as to avoid the double rejection, IMO. Maybe if it were shot from the back or a 90º angle it could have made that difference.
Quoting Dendrobatid (Reply 1):
Hi Mick, I thought that windsocks may give an idea of the level of the pic, but are they that reliable as a vertical reference? I´ve always been careful with these poles, because if they´re subject to strong winds, they may not be perfectly vertical in the end.
Cheers  Smile
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
Users browsing this forum: JKzhong and 1 guest
