Dazed767
Size - Give Me A Break!
Thu Dec 13, 2007 11:08 pm
http://www.airliners.net/procphotos/...?filename=20071213_N529USjcmco.jpg
Ok so my image was 1024x681 and apparently the minimum is x683. Come on now, can we nit pick just a little bit more here??
timdegroot
RE: Size - Give Me A Break!
Thu Dec 13, 2007 11:15 pm
Hi Justin
It's a nice image, just reupload at the minimum size. Make sure you set the crop tool to 3:2 in PS and you should always end up with images that have the correct ratio.
Tim
Alderman Exit
clickhappy
Thu Dec 13, 2007 11:28 pm
Quoting Dazed767 (Thread starter):
Actually your image was 1024x668, the copyright bar adds 13 pixels.
flipdewaf
Thu Dec 13, 2007 11:29 pm
That is actually really annoying because if you do a straight resize on the image from some nikon cameras (2000x3008) it comes out as 1024x681 they should let that through in my opinion but never mind. Its a really nice shot btw.
Fred
aero145
Fri Dec 14, 2007 12:19 pm
Quoting Clickhappy (Reply 2):
Well, a friend of mine, Eggert Norddahl, uploads in 1024x667, last time I checked, and he told me that he did that.
I noticed a long time ago that Jerrold Wu (Je89 W.) uploaded in 1024x693 (1024x681). His newest photo is like that, and all his nice pics I've checked in the past two years have been like that.
Note; I'm not trying to accusing anyone, I just noticed this. Yes, Jerrold's last photo was uploaded in late August, and Eggert's photo in the end of September, so I can believe the screeners got more strict since then.
Still, I do not know, and if I did, I wouldn't post this. I have uploaded pics in almost a 2:1 ratio here, so I'm not saying I'm any better with size than any others.  Silly
D
INNflight
Fri Dec 14, 2007 12:58 pm
Quoting Aero145 (Reply 4):
What's wrong with that? x683 is the minimum, so x693 is perfectly valid...!?
Jet Visuals
timdegroot
Fri Dec 14, 2007 1:00 pm
Just to clarify, anything in between 3:2 and 4:3 is perfectly fine with a minimum of 1000 pixel width
Tim
Alderman Exit
scbriml
Fri Dec 14, 2007 1:57 pm
Quoting TimdeGroot (Reply 6):
Of course, sometimes it makes perfect artistic sense to crop a photo at a different ratio to the one it was shot at.
Shot at 3:2, cropped to 4:3
Photo © Steve Brimley
aero145
Fri Dec 14, 2007 2:36 pm
Quoting INNflight (Reply 5):
683 is the minimum, so 681 is under the minimum. The "693" part was *with* the banner.  Smile
Stealthz
Fri Dec 14, 2007 2:59 pm
Quoting Flipdewaf (Reply 3):
And I believe they do but I could be wrong..
The image in question was not 681, it was 668.
Only 13px but the line has to be drawn somewhere!
ZakHH
Fri Dec 14, 2007 3:04 pm
I think the given limits make perfect sense. So why accept if they are missed by 15 pixels?
If missing by 15 pixels would be acceptable, then why would missing by 18 not be? Or 20? Or 25?
I guess it should be fairly easy to re-crop to 3:2. No need to bitch about nitpicking, imho.
Tired of a.net? Join a friendly aviation community!
dvincent
Fri Dec 14, 2007 3:35 pm
All of my 1024 wide shots are 1024x681 (without copyright bar, 693 with) and not a single one has been rejected for size. Canon sensors are slightly taller than Sony sensors (which the vast majority of other DSLRs use, including Nikon, Minolta, Pentax, and Sony themselves).
Fifteen pixels is about a quarter of an inch on most displays. Seems like a minor quibble to me, but I suppose the line is drawn somewhere...
From the Mind of Minolta
scbriml
Fri Dec 14, 2007 4:06 pm
Quoting Dvincent (Reply 11):
Regardless of the size of the sensor image, if you crop in 3:2 ratio and resize (with constraints) to 1024 wide, your image will be exactly 683 pixels high. The only way this won't happen is if you're resizing without doing any cropping, in which case, the sensor's ratio will be retained (which may not be exactly 3:2).
1024 / 3 * 2 = 682.666 (which PS rounds up to 683 since you can't have less than a whole pixel!)
[Edited 2007-12-14 08:10:46]
dendrobatid
Fri Dec 14, 2007 4:26 pm
The line has to be drawn somewhere and I cannot imagine any screener rejecting for a pixel or two out. As pointed out, take the copyright bar off and yours is well under size. We are far more lenient with oldies as mistakes in taking cannot usually be rectified
A pet peeve of mine is people never giving any thought to the composition of the image and the size that best suits the situation. Simply setting the crop tool to a given ratio and never considering any more is the way a lot of people do this. I am loathe to provide examples (they are very easy to find though) but the type of inappropriate size I am thinking of is a straight side-on of an airliner, say an A340 that is long and thin, yet the image is uploaded at 1024 x 768 when it would better fit at 1024 x 683.
My way is to use a freehand crop tool and to crop to suit the image - to compose it. When I re-size I simply make sure that it is within the permitted range.
I am not saying that my way is necessarily the right way, merely saying that the size and composition should be considered and my way is simply one way of doing that.
Mick Bajcar
dvincent
Fri Dec 14, 2007 4:59 pm
Quoting Scbriml (Reply 12):
I use the crop tool in Adobe Lightroom set at the original aspect ratio of the image.
The point is that it's so close as to be negligible because the sensor is actually slightly wider than "true" 3:2. If I resized to 683 tall, the image would be 1027 pixels wide. You get about three "free" pixels at the same height. The point is that size differences that small are nearly negligible.
scbriml
Fri Dec 14, 2007 5:16 pm
Quoting Dvincent (Reply 14):
OK, that makes sense and explains the "odd" size.
D L X
Fri Dec 14, 2007 5:38 pm
To the screeners and software folks: If I understand correctly, the screener page alerts the screener if the uploaded shot is not within the size guidelines. Could that be ported to our upload confirmation page? I think that could have prevented this minor tiff. (Get it? TIFF? hah.  Wink)
scbriml
Fri Dec 14, 2007 8:12 pm
Quoting D L X (Reply 16):
Get it? TIFF? hah.
Don't give up your day job!  smile
Dazed767
Sat Dec 15, 2007 4:57 am
Sorry I didn't have a chance to go back and look on my old computer as I was installing everything on my new build, so I didn't get to look and see it was 668, my fault. I'll try and keep an eye out so I don't do it again. I've just had so many rejections for minor stuff lately, it gets aggervating. Plus I haven't had much time to go back and re-edit everything again and upload.
I did get feedback from a screener on one rejection, which is always appreciated.
Thx,
Justin
Kereru
Sat Dec 15, 2007 7:27 am
Quoting Dazed767 (Reply 18):
I agree with that even though I was once a screener a long time ago. Things change and keep up the good work guys.  bigthumbsup
Colin  old
Good things take Time.
