Ridgerunner
New Photographer, This Phjoto Rejected.
Fri Dec 21, 2007 3:32 pm
I am new to airliners.net and I'm not having any luck with my photos. I would like to hear suggestions on this photo and any advise for dusk, dawn, and night photos. Thank You.
http://www.airliners.net/procphotos/...o.main?filename=20071221_N815E.jpg
clickhappy
RE: New Photographer, This Phjoto Rejected.
Fri Dec 21, 2007 3:45 pm
Hi Travis.
A couple of things
The crop is a little awkward, the missing wingtip on the left side takes away from the shot and the crop is a little loose on the right side.
But, the biggest hurdle you face is the overall quality, your shot is really grainy, soft, and lacking in contrast. A good place to start would be to shoot for a finished size of 1024 pixels wide.
Please browse the database to see the type of quality needed to be successful here.
Ridgerunner
Fri Dec 21, 2007 5:04 pm
I understand about the cropping, I was wondering if I should give up photos taken before sunrise. I don't know how to make it any sharper with such little light. That seems to elude me. I will keep working on better photos and will try some of my regular daylight shots first. Thanks.
Psych
Fri Dec 21, 2007 5:10 pm
Hello Travis.
What equipment are you using here - to take the photo and also to edit? I ask because the points Royal raises are key - personally I like the motive you have tried out here with the low light and the moon, but the quality/sharpness etc are just not there.
I would be happy to help out with an edit if you would like - you can contact me via my profile shoudl you wish.
All the best.
Paul
Skydoll
Fri Dec 21, 2007 5:47 pm
I'm new to Airliners.net, too, and this is my first time looking at the photography section, but I think your photo is nice. I like the pink sky and the moon. But I've got a lot to learn as well.
Heather
michlis
Fri Dec 21, 2007 6:29 pm
Quoting Ridgerunner (Reply 2):
I would suggest on working on getting more experience with taking photos with better lighting. Once you get the knack of proper exposure, then push the envelope.
If you know the enemy and know yourself, you need not fear the outcome of a hundred battles.
GUAMVICE
Fri Dec 21, 2007 6:46 pm
Quoting Michlis (Reply 5):
 checkmark
You will learn, as I have, that any photo worth uploading is a photo in good light. Once you have that apsect grasped, you can be a little more creative  Smile.
The two most engaging powers of a photographer are to make new things familiar and to make familiar things new. ~Thacker
scottieprecord
Fri Dec 21, 2007 7:01 pm
I did a quick edit of your shot, and I don't think it's that far off. I'm with Paul in wondering what equipment you're using, because the lighting and the actual exposure don't seem that bad to me.
Mike
dvincent
Fri Dec 21, 2007 7:04 pm
Quoting Scottieprecord (Reply 7):
I don't think the blurriness can be saved... this is where some form of IS would have really saved the day. I also see some noise. Was this taken on an SLR or a point n shoot digicam?
From the Mind of Minolta
CalgaryBill
Fri Dec 21, 2007 10:45 pm
Did you use a tripod?
B
Ridgerunner
Sat Dec 22, 2007 12:03 am
II took this with my digital Minolta, a 6 mega-pixel. I took this on the way out to get the plane ready, so I didn't have a tripod with me. I will say I'm much better at flying than taking pictures. I do take a lot of snap shots out the window, and never thought about sending any into this website until talking to a few friends (non-photographers, just aviation enthusiast) I do have a 35mm film camera too. That might help too and a lot of reading and looking at this site would go a long way to improving my pictures. Thanks to everyone for all the good information and I will be checking back in after the holidays. Travis.
viv
Sat Dec 22, 2007 12:12 am
Quoting GuamVICE (Reply 6):
Nonsense. I have many uploads taken in bad light.
dvincent
Sat Dec 22, 2007 12:39 am
Quoting Ridgerunner (Reply 10):
An SLR? Or was it one of the little Z cams? The 6mp Z3-5 have terrible noise response unfortunately, even with the help of antishake (which they had) at ISO 100. Definitely too may pixels on that one.
Remember to keep Antishake on in low light conditions and use as wide of an angle as you can - if you can keep the shutter speed around 1/50 to 1/8 you should be able to get something usable.
Ridgerunner
Sat Dec 22, 2007 4:32 am
The camera is a Minolta Dimage Z-6. I'm sure my 35mm film would do much better. I carry the digital around for ease of use and just for snap shots out the window.
viv
Sat Dec 22, 2007 9:48 am
Quoting Ridgerunner (Reply 13):
It would, but you would then have the problem of scanning the negatives into your PC. Flatbed scanners are not really able to do this with the required quality.
dvincent
Sat Dec 22, 2007 2:36 pm
For the love of god make sure you keep the antishake on!  Wink It'll really help you in these low light situations. But if your exposure time goes over a second, it won't help and you'll need a tripod.
Also try to keep it at ISO 50 or 100. You need to keep your noise down as much as possible.
What do you have for a 35mm? Canon? or Nikon?
Quoting Viv (Reply 14):
It's all in the scanner operator. And, well, a good scanner with digital ICE helps. I've scanned many a slide and neg on my Epson 4490. For an inexpensive scanner it produces really good scans.
Ridgerunner
Sat Dec 22, 2007 3:08 pm
My 35 mm film is a Minolta. My scanner is a Epson V100, a flatbed scanner that can scan negatives too. I seem to have good luck with my digital camera in normal lighting. I think I will spend some time practicing with exposure in different light situations. I might have some time off to go practice soon, then I will try again. Thanks.
USAir_757
Sat Dec 22, 2007 9:12 pm
Quoting Dvincent (Reply 15):
Not true with flatbeds. I've tried many, they are meant for prints are quite simply unable to produce high-quality scans of film. If you lay the slide film directly on the glass without using the "adapter" you get rainbow patterns all over the place, and if you use the "adapter" you get out-of-focus/doubled images.
Dedicated film scanners on the other hand still can produce as good of results as digital (if not better depending on the scanner, film and operator)
-Cullen Wassell @ MLI | Pentax K5 + DA18-55WR + Sigma 70-300 DL Macro Super
dvincent
Sat Dec 22, 2007 9:16 pm
Quoting USAir_757 (Reply 17):
I've scanned dozens of negs on my flatbed Epson with little trouble, but I admit it's not the same as using the ole drum or a Minolta Dimage film scanner.
Digital ICE really helps, though.
USAir_757
Sat Dec 22, 2007 10:07 pm
Got some examples? I'm open to being proven wrong...
dvincent
Sat Dec 22, 2007 10:41 pm
Quoting USAir_757 (Reply 19):
Nothing aviation related, I'm afraid, but here's a good example.
Scaled down a bit for the web, but it wasn't bad for an ISO 100 Fuji slide with my old manual focus Yashica. The worst problem is grain but today's software makes that negligible. It's not something I'd make a huge print of, but it's very serviceable.
I used to do film scans as part of the print I used to do. Now I'm out of that business, and I won't disagree with you about true film scanners being the best, but a good (read, not $100) flatbed with a good transparency handler (such as the Epson Perfection 4490) and Digital ICE can scan slides or film for good results.
[Edited 2007-12-22 14:44:07]
