EMA747
Zurich Stop-over Please Help.
Fri Dec 28, 2007 1:18 pm
I am going to see a friend in HAM but will be flying Swiss via ZRH. I have heard a lot of good things about spotting in ZRH so I want to get clued up so I don't miss anything during my short stay.
What is the afternoon like for traffic? I can get a flight that arr at 11:40 and leaves at 17:35. If the afternoons are not worth it then I could just get a quick connection and do some spotting on the way back. On the way back I can get a flight that gets to ZRH at 21:20 on Sat and leaves at 12:10 on Sunday. I have heard the early mornin (6-9am) is good for heavies, is this right? Also is it true that there are some very basic rooms that you can get in the airport for about 60CHF? Is Sunday morning good for heavies or is another day better? I can get that overnight stop any day I think.
Where are these pics taken from? Are they palces I can get to without a car?
Photo © Jerome Zbinden
Photo © Samuel Schneeberger
Photo © Moritz Meier - ILS Spotting Group
Photo © Rotate
Photo © Rafael k - Art on Airports
Photo © Mark Tang - HKAEC
Thanks for any help.
Andy S
Failing doesn’t make you a failure. Giving up and refusing to try again does!
ketko2
RE: Zurich Stop-over Please Help.
Fri Dec 28, 2007 1:36 pm
Hi,
believe it or not, I have just stop over in ZRH, spotting is great from terrace, and most of photos you have shown are there.
Dont know about the rooms tho.
I booked longer connection to spot too. I think its worth it.
Regards, Keishi
whisperjet
Crew
Fri Dec 28, 2007 1:55 pm
Hi,
check out this spotting guide for ZRH. Imo it's very good because there are also bus connections to the spots mentioned.
http://www.planepics.org/files/zrhspotting.pdf
Stefan
Nobody is perfect - not even a perfect fool.
EMA747
Fri Dec 28, 2007 2:16 pm
Quoting Ketko2 (Reply 1):
I wish I could get a flight out in the evening but I think it's a special price that does not really allow too long a stopover. It's £99 with the flights I quoted but it's more like £199 if I had a longer stopover. If I could get from ZRH to HAM cheap then I coudl just get a flight BHX-ZRH and choose how long I stayed in ZRH.
ruudb
Fri Dec 28, 2007 2:47 pm
Around noon the most big aircraft are leaving Zurich, only the aircraft of the USA leave "early" the Singapore Airlines (think you like it very much looking at the selection you made) around 14:00 at the time I visited Zurich. The only problem you can have at Zurich is fog, seems they have more fog as anywhere else.
carlos
Crew
Fri Dec 28, 2007 3:01 pm
Hi Andy,
I would say No 2 is made from the top of the parking lot. It look similar to this one:
http://www.airliners.net/open.file?id=1257842.
No 1,3, 5,6 looks like the terrace in ZRH.
Klaus
EMA747
Fri Dec 28, 2007 3:07 pm
What runway is most likely to be in use? Is there one that is used most of the time or is it pretty random?
ruudb
Fri Dec 28, 2007 3:20 pm
If you take a look on the link whisperjet included, there is a list of runways in use, the big jets use runway 16 normally and the smaller ones 28, arrival of all jets is on runway 14 during the periods I have been there.
JakTrax
Fri Dec 28, 2007 3:25 pm
The terrace at ZRH is great until just after midday, with the ideal runway use being 34 as then all traffic must taxi past you. Shots into the cul-de-sac are the only option if the wind favours runway 16 (which it usually does), however you can get some nice portraits, although most of it will be Swiss.
If I remember rightly, car park F is good for taxi shots in the morning (it overlooks the threshold of the cross-runway), although heavies normally do not use this runway.
The Wanderweg is within walking distance but I forget how to get there. Takes about 20 mins from the terminal. It is somewhere near the GA ramp and is good for line-ups but that's all I can remember I'm afraid.
The other spots are well away from the airport and require a car.
Karl
EMA747
Sun Dec 30, 2007 3:46 pm
Does anyone know if the airport bus tours run on a Monday and if so at what times and can you buy a ticket on the day?
Also, how much does it cost to get the train to Zurich town and how long does it take?
whisperjet
Crew
Sun Dec 30, 2007 4:11 pm
Hi,
there are no bus tours on Mondays.
It takes app. 20 minutes to get from the airport to the city centre.
Stefan
Domjan
Sun Dec 30, 2007 10:18 pm
Hi Andy,
you can find arrival/departure information here -- sorted even by airline and/or aircraft type, if you wish.
Hans
gerardo
Mon Dec 31, 2007 1:04 am
Some 1st hand spotting infos can be found here: www.dominguez-online.ch
For any more questions, drop me a mail.
Gerardo
dominguez(dash)online(dot)ch ... Pushing the limits of my equipment
Users browsing this forum: Borut and 1 guest
