mirrodie
Have You Had This Problem With Canon 100-400
Tue Jan 08, 2008 4:20 pm
A fwe months ago, I noticed that when I zoom in, then zoom back out, it seemed that there was some resistance to zoom out the lens. it's an on and off phenemonon and hte shots are unaffected.
YEsterday while spotting with a friend, he diagnosed my issue. One of the black internal rings ( I forget the proper name) which can be seen when you look head on at the lens, was loose and falling backwards toward the camera body.
I am wondering if anyone else has experienced this. And hte cost of repair at Canon?
Forum moderator 2001-2010; He's a pedantic, pontificating, pretentious bastard, a belligerent old fart, a worthless st
timdegroot
RE: Have You Had This Problem With Canon 100-400
Tue Jan 08, 2008 8:07 pm
Yes I've had this (or a similar) problem. It got so bad I could not move the zoom ring any longer. It was still under warranty so not sure what a repair will cost.
Tim
Alderman Exit
whisperjet
Crew
Wed Jan 09, 2008 11:40 am
Hi,
I had the same problem but it was under warranty too. Seems to be a quite common problem with the 100-400.
Stefan
Nobody is perfect - not even a perfect fool.
GVerbeeck
Wed Jan 09, 2008 4:09 pm
I've had mine repaired for a similar problem not under warranty. Cost me around € 120.
maiznblu_757
Wed Jan 09, 2008 5:58 pm
Quoting Mirrodie (Thread starter):
Yes, I have had the resistance issue with the 100-400mm but mine was caused by the bearings not functioning correctly. I have the Mack Warranty which adds 3 years on to the Canon warranty. Mack was unable to fix it so they sent it to Canon for the repair.
I had a friend that went to Phancon a couple of year ago and his lens got stuck at 400mm, it wouldnt budge. The bearings were the cause again.
Advice, use the opportunity to have Canon check the sharpness of the lens from 300-400mm. A lot of people complain of the lens being soft in that range. Its a peace of mind thing.
[Edited 2008-01-09 09:59:05]
aero145
Wed Jan 09, 2008 9:30 pm
I have a bit of this problem with my 100-400. It's in EU warranty for a few more months now, but I really doubt Canon Iceland will want to fix that (not sure if they've ever had to fix a 100-400 at all  Silly).
I remember "TZ" said something about putting some liquid on the barrel, will be nice to see if he'll reply to this thread.
Atb,
D
IngemarE
Wed Jan 09, 2008 9:40 pm
Throw it away!, and pamper yourself with this one.........  drool  http://www.canon.com/camera-museum/c...per_telephoto/ef_1200_56l_usm.html
......there's a rumour about one being up for sale somewhere in California!
Even I would give a brand-switch a thougt, if I had the cash to spend that is!  cheeky
In thrust I trust.
AA 777
Wed Jan 09, 2008 11:31 pm
Mario,
I had the same problem with mine last year. I drove it down to Canon in NJ...exit 8A I believe on the NJ TPK. They mailed it back to me in a week and it was about 100 bucks I believe!
CRJ-700 FO
mirrodie
Thu Jan 10, 2008 3:05 am
Thanks all, much appreciated, esp. aa777.
Mario
NSMike
Thu Jan 10, 2008 3:12 am
Quoting IngemarE (Reply 6):
Throw it away!, and pamper yourself with this one......... http://www.canon.com/camera-museum/c...per_telephoto/ef_1200_56l_usm.html
B&H has one for sale...
http://www.bhphotovideo.com/c/produc...Super_Telephoto_1200mm_f_5_6L.html
As to the OP my 100-400 had the same problem. The plastic ring inside the front element came loose, preventing it from zooming. It was fixed under warranty.
Pearl Snares, Taye Drums, Sabian Cymbals, Remo Heads, Los Cabos Sticks
sulman
Thu Jan 10, 2008 8:48 am
I remember Peter Fagerstrom saying he had a single grain of sand in his that caused his 100-400 to lock solid. EGHI local Justin Wood has his 100-400 fail in the same way the thread author described; I believe Canon fixed it under warranty.
TZ's trick was a rag with WD40 on it applied gently around the telescopic part of the barrel, If I recall correctly.
James
[Edited 2008-01-10 00:48:38]
