sfilipowicz
Rejected For Level. Really?
Thu Jan 17, 2008 1:19 pm
Photo was rejected for 'LEVEL' personal message said need some CW rotation.
How come it needs CW rotation?? Photo was taken at Lusaka Airport in Zambia, the ground there is not so level. Just look at the background you see that the ground is not level. Looking at the trees in the background it seem perfectly level to me. Or am I wrong? I just don't get it anymore, if it's not LEVEL then it would be something else. Would the viewer even care one little bit that the photo may be 0.1% of level? Looking at the trees the photo is perfectly level!!
Sorry guys just a bit of frustration.
http://www.airliners.net/uf/view.fil...2489&filename=1200575383kADrBD.jpg
[Edited 2008-01-17 05:26:35]
michlis
RE: Rejected For Level. Really?
Thu Jan 17, 2008 1:21 pm
Well, just give it some CW rotation and re-submit it. No big deal.  Yeah sure
If you know the enemy and know yourself, you need not fear the outcome of a hundred battles.
JakTrax
Thu Jan 17, 2008 1:23 pm
You're right; there's clearly an upward curve from left to right in the horizon - but don't forget that it's not awlays black-and-white, and sometimes we must use judgement to make the image 'look' level - even if in fact it turns out not to be.
I'm afraid this shot doesn't 'feel' level, and therefore it will be classified as unlevel.
Karl
ranger703
Thu Jan 17, 2008 1:31 pm
I levelled CW by 1.0! I used the masts in the background as a reference.I also brightened the shot slightly and came up with this:
http://img.photobucket.com/albums/v332/amwaluk/anetmod.jpg
Andy
PS.just seen the frame in the bottom right hand corner,you obviously won't have a problem when cropping.
[Edited 2008-01-17 05:33:41]
sfilipowicz
Thu Jan 17, 2008 1:40 pm
Thanks guys and thanks Andy.
I can understand that the modified image might seem beter level. But for me it looks wierd, being at the airport the runway is at a slope. But if rotating the earth will get it accepted then I would just need to do that.  Smile
Cheers!
Steven.
timdegroot
Thu Jan 17, 2008 1:53 pm
Hi Steven
With all due respect there is no way your image is level, every single indicatror point to ccw rotation and andy's version is much better.
Just reupload with the corrections, it's a rare image but even those need to be level.
Tim
Alderman Exit
timdegroot
Sorry cw rotation
Tim
Alderman Exit
sfilipowicz
Thu Jan 17, 2008 2:06 pm
Ok thanks everyone, I will re-upload with some CW. Thanks!
Steven
PS: But I still don't agree  Smile
