Jawed
Tripod Recommendations?
Fri Jan 25, 2008 1:43 am
I'm looking for a tripod for my Nikon D80, and I figured I would ask what brands and models you guys like to use.
The general requirements are: ultra light, ultra portable, flexible on price.
Thanks for any tips!
whappeh
RE: Tripod Recommendations?
Fri Jan 25, 2008 1:49 am
Define ultra-light and ultra-portable? I've never had a problem with my tripod. Its not as light as it can be, but its no inconvenience... same with portability. How portable do you really need? Do you want something small enough to fit into a suitcase? If so, then you're going to trade off on price and quality of the tripod it self (in terms of stability).
All that said, I use a pretty hefty Manfrotto 3021Pro. Its a beast and will probably last 20 years as long as I don't drop it more then 30 feet.
-Travel now, journey infinitely.
ptrjong
Fri Jan 25, 2008 1:51 am
I'll steer clear of Velbon in the future - the head of my copy broke after less than 10 months.
Peter
monteycarlos
Fri Jan 25, 2008 1:53 am
I wouldn't look any further than Manfrotto... you can get a variety of different leg + head combinations or you can buy single assembly ones (such as mine) which are excellent.
How much is you max price limit?
It's a beautiful night to fly like a phoenix...
Jawed
Fri Jan 25, 2008 2:06 am
Sounds good. There is no price limit... I intend to use this for 20 years if it lasts that long.
Quoting Monteycarlos (Reply 3):
monteycarlos
Fri Jan 25, 2008 3:57 am
My suggestion would be:
Manfrotto 055 PRO B tripod with a Manfrotto 329 RC 4 head on it... that ought to give you some flexibility and durability.
CalgaryBill
Fri Jan 25, 2008 7:38 am
 checkmark
Quoting Monteycarlos (Reply 5):
Manfrotto 055 PRO
The 055 is a classic. I've had some version of the 055 for over 20 years and they've spent weeks out winter camping, been filled with sludge while shooting in marshes, and done tons of studio work. I recently sold my first one - over twenty years old and still had some value!
I would avoid the carbon tripods from Manfrotto (likely all the other brands too, but my personal experience is with Manfrotto). A photo colleague tripped on mine and one of the clamps and a leg segment shattered. In fairness, parts were incredibly easy to order and reasonably priced (clamp $20, carbon leg segment $50) but this thing can not take the beating the metal ones can and by the time you put a head on it, the weight difference between metal/carbon isn't much. A friend had a Gitzo (about 30% more expensive than Manfrotto) carbon tripod and a couple weeks after she bought it, one of the legs just fell out of the triple clamp at the top.
B
ptrjong
Fri Jan 25, 2008 8:08 am
That intimidated me... why are there different heads? Don't they all do the same job?
My suggestion would be: Manfrotto 055 PRO B tripod with a Manfrotto 329 RC 4 head on it...
So yours is not a single assembly?
Peter Smile
CalgaryBill
Fri Jan 25, 2008 8:37 am
Quoting Ptrjong (Reply 7):
They all do different jobs, depending on the situation. There are fluid heads for panning shots (mainly used in film/video), ball heads for quick-n-easy repositioning of the camera, triple axle heads for precision setup (they're usually cheaper too). How much you spend will generally determine how versatile and rigid the head is.
If THAT intimidated you, check out the Wimberley heads - some of them cost up to $700 (but they're pretty schwanky).
B
javibi
Fri Jan 25, 2008 9:36 am
Quoting Jawed (Thread starter):
ultra light
That is not what you want from a tripod, specially if you are going to use a heavy lens with it and you want it to last +20 years. If the tripod is ultra light it is unlikely it will be rigid enough.
j
Buyantukhaa
Fri Jan 25, 2008 11:13 am
I use the Manfrotto 785B (or HB?). Cost EUR70 and suits me fine. No idea whether it's metal or carbon, but it's relatively light and fits in any ordinary backpack. Only thing that I now have a 70-200 f4L lens and it's difficult to get in the right position, even with a tripod ring (it's actually back-heavy even with an EOS400D). But once the position is good it stays good, at least.
I scratch my head, therefore I am.
viv
Fri Jan 25, 2008 11:14 am
Heavy means steady - the first requirement of a tripod. Go for a Manfrotto carbon fibre one.
timdegroot
Fri Jan 25, 2008 11:42 am
I have the manfrotto 055 and have always been very pleased with it. Sturdy, practical, durable and not too heavy while still providing enough support for medium weight lenses like the 100-400. Even my 300 2.8L fitted nicely on it.
Tim
Alderman Exit
Jawed
Fri Jan 25, 2008 7:43 pm
Would a beast like the Nikkor 200-400 fit on this without it toppling over?
Quoting TimdeGroot (Reply 12):
Tim
CalgaryBill
Fri Jan 25, 2008 9:20 pm
Quoting Jawed (Reply 13):
I use the Wimberley/055 combo for that lens on a D3 and the 055 can take the weight easily.
Quoting Viv (Reply 11):
Can't agree with you on that one. Mine broke just because someone tripped on it! Broke a leg segment and clamp - the clamp itself was a powdery aluminum/unknown-substance alloy that just shattered. Next time it breaks it goes in the garbage. I have two 055's and a smaller metal Manfrotto and they are the workhorses.
B
ruudb
Fri Jan 25, 2008 9:24 pm
You just must buy the right head they have them in different weight categories, so there are heads for lesser and higher weights too, read a ballhead isn't strong enough for a high weight combination of lens and camera. By the way I use a Manfrotto 55 too, I think it really is a great and easy to use tripod. And there is an "eye" on it to hang something heavy on, sometimes I use my bag, it makes your tripod more stable.
ake0404ar
Fri Jan 25, 2008 9:55 pm
Quoting Jawed (Reply 4):
hmmmmm, you could easily spend 1200 USD on a nice set up, but the question is, is it really necessary at this point?
If money is no issue take a look at the Gitzo GT1540T (Traveler)........I personally own the 1504 and have had it for about 6 years, no complaint so far.
Quoting CalgaryBill (Reply 8):
but worth every penny.....!
Vasco
monteycarlos
Tue Jan 29, 2008 12:23 am
I have a single assembly one, but have also used the 055 PRO B and the RC 4 combo head one which is far superior than anything else I've used. Perfect for photography with medium weight lenses and even video camera applications.  Smile
CalgaryBill
Tue Jan 29, 2008 3:34 am
Quoting AKE0404AR (Reply 16):
That's why I have one...  Big grin
Something to consider with a Whimberley is you also have to buy compatible plates for it. The one for the 200-400 is over $100 here in Canada. But as Vasco said, well worth the money.
B
ake0404ar
Tue Jan 29, 2008 7:09 pm
The Wimberley is such a joy to work with, especially with larger lenses. The only drawback, you need a dedicated tripod, unless you want to change "heads" all the time. The compatible plates are a must!
Now I only need a light tripod when traveling. The Gitzo 1504 almost killed me during my last Dubai trip.......
Vasco
CalgaryBill
Wed Jan 30, 2008 6:03 am
Quoting AKE0404AR (Reply 19):
One of the tripods I use it on is a Manfrotto carbon model. The top four inches of the center column can be removed simply by unscrewing it from the bottom (rubber knob, no tools required). If you call the distributor (Amplis in Canada) the center piece is only $20 or $30, so I bought a couple extras to mount different heads. It isn't much more expensive than the plates.
Now if only one of their aluminum models had the same feature....
B
Jawed
Fri Feb 01, 2008 4:32 am
What do you guys think of the Gitzo GT3530 tripod combined with an Acratech 1150 ball head? I checked it out at a store today, and didn't find any obvious short comings.
[Edited 2008-01-31 20:37:16]
CalgaryBill
Fri Feb 01, 2008 5:04 am
Quoting Jawed (Reply 21):
The biggest drawback with Gitzo is the price. The gal at my camera store bought one and one of the legs fell right out of the top section. They're only glued in.
After the experience I had with my Manfrotto, I would not buy another carbon tripod. Aluminum isn't much heavier (and the weight helps the stability anyway), it's certainly more durable, and it's half the price of carbon.
B
soon7x7
Fri Feb 01, 2008 5:51 am
For the last twenty years I have been using the Manfrotto 3221 w/ the 3030 head. I have mounted my Nikon 600mm f4 on it...was fine...I prefer it to be on a larger one I have w/ wimberly but this 3221 has travelled all over the world with me. No other tripods I have used perform like this one does. I constantly use my Hasselblad on it. Heavier than carbon fibre but baggage handlers get a hold of carbon fibre, IT WILL BREAK...don't want to carry it?...wear it...it comes with a great neck strap...My advice is stay away from ball heads if your using eqpt with some weight...I found the Gitzo I had to be very heavy and brittle...Star D was ok...not sure if they are mftrd anymore. The type head you use depends much on the way you shoot...many photogs swear by ball heads, they are actually easiest to use but I find them to be a pain where beefy lenses are considered, also if you loose you grip on the lens , the ball head acts as though the cameras going to fall off the tripod resulting in you lunging after it , ultimetely causing you to freak and possibly knocking over the whole thing....(lesson learned with 300mm 2.8 mtd on ball head)...Got rid of ball head, kept lens, got new 3030 head...happy and ready to go...Cheers...Jerry
600mmf4
Fri Feb 01, 2008 4:11 pm
I have combined the Manfrotto 055 with the video head 501,its only up to a maximum of 6 KG,but it takes the all in all 7,5 KG Nikkor 400mm f2,8 + 2x extender + the D2Xs without any problems,easy to handle with an extra long lever and-very important-damped,so even when you forget to fix the heavy combo the whole thing wont fall down.
Achim
CalgaryBill
Fri Feb 01, 2008 5:10 pm
Quoting 600mmf4 (Reply 24):
How does that perform in extreme cold? We just went through a -30 week of weather in Calgary and it got me wondering how damped heads handle. Does the fluid or lubricant seize up?
If I have time today I'll try the same question with the Wimberley and see how it goes...
B
600mmf4
Fri Feb 01, 2008 10:07 pm
Cant answer you that question because we dont have cold winters here in the last years....sorry.
JRadier
Fri Feb 01, 2008 10:25 pm
Quoting Javibi (Reply 9):
As they say with tripods:
"Light, Strong, Cheap... pick 2"
As for me I'm using a Manfrotto 055CLB which I used to couple with a 141RC 3-way head. Works like a charm although I've upgraded my head to a 410 (geared) which I think works better for aviation photos (easier to make tiny adjustments).
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
Users browsing this forum: Google [Bot], vishaljo and 1 guest
