A380fo
First Attempt At Screening....
Tue Jan 29, 2008 5:28 am
I am so reluctant to attempt to post pictures on here because of the tight guidelines. but i think im gonna try. this thread is to let me know what i need improvement on with taking pics, and what i need to do to the pics IF they have a chance.....here they go, all help is so grateful!!
http://farm3.static.flickr.com/2009/2228016270_805df0d7b9_o.jpg
http://farm3.static.flickr.com/2235/2228010708_2fc44388eb_o.jpg
http://farm3.static.flickr.com/2181/2228004958_e660492d0b_o.jpg
http://farm3.static.flickr.com/2272/2227993796_6830e541e6.jpg
http://farm3.static.flickr.com/2323/2228024354_cdff281863_o.jpg
http://farm3.static.flickr.com/2350/2228027370_2a5976ea0e_o.jpg
http://farm3.static.flickr.com/2183/2228033372_a0ae322c57_o.jpg
thanks
whappeh
RE: First Attempt At Screening....
Tue Jan 29, 2008 5:40 am
I'm not the best person to give advice, BUT, I can tell you that in order for them to make it (if they even have a chance) they all need some work.
-Travel now, journey infinitely.
A380fo
Tue Jan 29, 2008 5:43 am
yea i know that but i wanna know what needs to be worked on
unattendedbag
Tue Jan 29, 2008 5:52 am
Quoting A380fo (Reply 2):
first of all, you need to edit them to proper size. we cannot see flaws in thumbnail photos. make them 1024pixels wide x 683 pixels tall and repost them.
Slower traffic, keep right
Stealthz
Tue Jan 29, 2008 5:57 am
Size is one, the site has pretty strict criteria on size & aspect ratio, images should be 2:3 aspect ratio(same as 35mm film & most DSLRs) or 4:3 l(most P & S cameras and conventional TV) Min. of 1000 px on the long side.
A couple of the images have significant level issues and all are dark and could benefit from some decent post processing.
WestJetYQQ
Tue Jan 29, 2008 6:05 am
I really like the ones of the A380s nose. Hope it makes DB.  Smile
Will You Try to Change Things? Use the Power that you have, the Power of a Million new Ideas.
A380fo
Tue Jan 29, 2008 6:13 am
2-VX A320
2-dl 757 slowing down
2- the beast
welcome onboard the A380-2
http://farm3.static.flickr.com/2272/2227993796_5de12b58ab_o.jpg
A380fo
Tue Jan 29, 2008 6:33 am
a few more i missed
http://farm3.static.flickr.com/2242/2227325375_7cdb1b2778_o.jpg
http://farm3.static.flickr.com/2303/2228130434_f232572c0a_o.jpg
javibi
Tue Jan 29, 2008 11:40 am
Quoting StealthZ (Reply 4):
1024 pixels minimum, AFAIK.
j
DeltaAVL
Tue Jan 29, 2008 11:42 am
Unfortunately, all of these suffer from quality issues and there's only one thing you can do about that - get a better camera.
"We break, We bend, With hand in hand, When hope is gone, Just hang on." -Guster
Fly747
Tue Jan 29, 2008 12:16 pm
Quoting Javibi (Reply 8):
It's actually 1000 wide.
http://planecatcher.com/IGRR/Size.htm
Ivan
Granite
Tue Jan 29, 2008 1:02 pm
Oh
From the thead title I though we had a new screener that missed my interrogation  tongue
Gary
javibi
Tue Jan 29, 2008 5:52 pm
Quoting Fly747 (Reply 10):
I stand corrected, if that is the case.
j
Stealthz
Tue Jan 29, 2008 7:36 pm
Judging from some of the photos in your 2nd & 3rd batch, You are not paying attention!
That will alienate other members more than anything.
Jetfreak
Tue Jan 29, 2008 7:43 pm
Hi,
i like the motives (especially the a380), but there´s too much digital noise. Which camera do you use?
Jetfreak
A380fo
Tue Jan 29, 2008 11:24 pm
i am using my dads' friends Canon Digital Rebel XTi
i dont get the aspect ratio thing??
KPWM
Wed Jan 30, 2008 12:27 am
All these photos seem a little grainy. Maybe you saved the pictures on your computer in a lower quality.
94
A380fo
Wed Jan 30, 2008 2:10 am
how could i make them look better? like for instance, less grainy?
Fly747
Wed Jan 30, 2008 2:18 am
Quoting A380fo (Reply 17):
Too late now, but next time, shoot at lowest possible ISO and properly expose your images. Underexposure causes noise.
There are some softwares which reduce noise as well, such as NeatImage and Nosie Ninja, but proper exposure should be your preferred way to less noisy images.
Ivan
thijhijz
Wed Jan 30, 2008 11:01 am
They a look at bit grainy, but also the quality doesn't meet the A.net standards.. I like the one with the A380 nose close-up, but all the other pictures might be rejected for common. Good luck!
sulman
Wed Jan 30, 2008 11:06 am
Something's not right here.
I think the images we are seeing are up-sampled from flickr. If that's the case, that explains the very strange quality issues with them.
Do you have anywhere you can post the original files, straight out of the camera?
James
Silver1SWA
Crew
Wed Jan 30, 2008 12:12 pm
Quoting DeltaAVL (Reply 9):
Poor quality is often indicative of poor photography and not always a sign of a poor camera. The fact that he was using a Rebel XTi shows that's probably the case here.
Not to sound too harsh here A380fo, but it appears you have some learning to do. Learn the camera, learn some basic photography then learn some basics in post processing, and that will be the first step to learning airliners.net and it's guidelines. It can be a slow process that may involve multiple trips to the airport so you can put everything you learned to practice.
As far as airliners.net criteria, some immediate issues I see are:
- They are not correctly leveled.
- Some are back-lit. While not always a must, it is generally a good idea to shoot with the sun at your back.
- The aircraft are not correctly centered.
- And of course, as mentioned they need to be within the correct size and aspect ratio limits.
Quoting StealthZ (Reply 13):
Quoting Sulman (Reply 20):
I believe that is the problem. Click on the photo to bring up the link to flickr where the photo can be viewed - in full - in a larger size.
[Edited 2008-01-30 04:16:03]
