opso1
Harrier Cockpit- Motive?
Fri Feb 08, 2008 9:22 am
Big version: Width: 1040 Height: 693 File size: 266kb
closeup
I've got this in the queue at the moment, but I'm worried that some motive issue will result in it not being accepted. Is it OK?
OPSO1
Stealthz
RE: Harrier Cockpit- Motive?
Fri Feb 08, 2008 9:45 am
Quoting Opso1 (Thread starter):
but I'm worried
Don't be, it is fine photo and I am glad I saw it.
If the site does not accept it, that is not always a criticism of the photo.
ThierryD
Head Support
Fri Feb 08, 2008 10:20 am
Opso,
I see the following issues with your shot: backlit (dark), softness, grain and empty space above the cockpit (motive).
Thierry
"Go ahead...make my day"
Stealthz
Fri Feb 08, 2008 11:04 am
Quoting ThierryD (Reply 2):
With all due respect Thierry, tell me how the motive(or the artistic merit) would be improved by reducing that.
Silver1SWA
Fri Feb 08, 2008 11:54 am
If closeups/tight crops around the cockpit windows of large airliners like the 747 are acceptable here, then I don't see why this should be any different. However, I do agree with the grain comment above.
timdegroot
Fri Feb 08, 2008 12:02 pm
It's a nice shot but the grain will lead to a rejection.
Tim
Alderman Exit
walter2222
Fri Feb 08, 2008 12:13 pm
I agree with Thierry, but I still like the shot! Close-ups will always remain a very subjective motiv, some like it, some don't...
I would also prefer somewhat less empty space above the canopy...
I had this one rejected long time ago:
MyAviation.net photo:
Photo © Walter Van Bel
I have no idea whether it would be acceptable under the relaxed motiv rules?
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
Stealthz
Fri Feb 08, 2008 12:23 pm
Quoting Walter2222 (Reply 6):
Once again, with all due respect..
The Anet policy of cropping to "within a pixel of it's life" can only be taken so far.
I had a go at cropping Opso1's image a little tighter and it did not work for me.(admittedly I did not have access to the original)
I think the photo as posted properly places the working aircraft within it's environment.
Chris
Quoting TimdeGroot (Reply 5):
I am not commenting on the quality/grain criteria
ptrjong
Fri Feb 08, 2008 12:31 pm
[quote=Walter2222,reply=6]I
Walter, yes I, would think that has a chance under the changed rules. You're certainly allowed to retry.
I would prefer somewhat more empty space above your canopy, though Wink
Peter Smile
ThierryD
Head Support
Fri Feb 08, 2008 12:34 pm
Quoting StealthZ (Reply 3):
Chris, I know what you mean but I didn't comment with regards to my personal taste but only how I think A.net screeners will see it and they mostly like closer crops.
Thierry
walter2222
Fri Feb 08, 2008 1:55 pm
Quoting Ptrjong (Reply 8):
But it would get "double" today,because I remember now that I uploaded another shot (shot taken same day, same side of the aircraft) of the T-Bird...
I agree, Peter, I would too, but unfortunately this was as it was shot, no cropping performed...
Walter
opso1
Fri Feb 08, 2008 5:22 pm
Big version: Width: 1040 Height: 693 File size: 170kb
de-grained
I've used Neat Image to get rid of some of the grain. Leaving the space at the top shows that the aircraft is on board an aircraft carrier rather than on land- something a bit different (not that something different is to everyones liking!).
Is this any better?
OPSO1
michlis
Fri Feb 08, 2008 5:38 pm
Quoting Opso1 (Reply 11):
Agreed, but that ocean must play hell with your exposure.
Kind of kills the quality of the image...there are noticable artifacts in the photo right below the canopy.
If you know the enemy and know yourself, you need not fear the outcome of a hundred battles.
