flynavy
Does This Crop Work?
Mon Feb 11, 2008 3:35 pm
So, in good faith I'm uploading photos again. I have a full que and eagerly await my screening results but I have a question about one shot in particular...
[image removed]
Now, for me, this crop just simply works. Unfortunately when I include the vertical stabilizer the crop just doesn't jive with me. Isn't the lighting on that shot just stunning? I was blown away this morning when I took it just after sunrise. I really would like this photo to be uploaded into the database! So, how does she look? Fire away!
Here's a different crop but with the vertical stablizer:
Chris in Atlanta
[Edited 2008-02-11 07:38:53]
[Edited 2008-02-11 08:07:43]
Change is: one airline, six continents!
Fly747
RE: Does This Crop Work?
Mon Feb 11, 2008 3:47 pm
The first one doesn't work for me. I would either crop tighter, center the engines and cut the vertical stab like you did, or use the second image. More balance for me that way.
Ivan
scbriml
Mon Feb 11, 2008 3:58 pm
IMHO, cutting off the tail when you have "dead space" below the nose wheel, seems "wrong".
If you do want to centre the fuselage vertically, I would, as suggested by Fly747, crop much tighter on the engines (especially on the left-hand side of the photo). This will have the benefit of also reducing the vertical space available for the shot.
The socond crop works fine for me personally  wink
Photo © Steve Brimley
flynavy
Mon Feb 11, 2008 4:02 pm
Thanks for the input fellas. Here's another take:
Big version: Width: 1280 Height: 853 File size: 757kb
KaiGywer
Crew
Mon Feb 11, 2008 4:03 pm
I like the last one the best  Smile
jamesbuk
Mon Feb 11, 2008 4:15 pm
Quoting Flynavy (Reply 3):
I like that - apart from the cut elevator on the left side (as you view) I think the elevator should be completely shown.
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
flynavy
Mon Feb 11, 2008 4:23 pm
I'm going to upload this one, again thanks for the input:
Big version: Width: 1280 Height: 853 File size: 731kb
acontador
Mon Feb 11, 2008 4:29 pm
Hi Chris,
Personally I'm not a fan of chopping-off tails, unless you want to achieve something very specific and there's no other choice. In your case, I would go for a crop like Steve is suggesting, centering the fuselage horizontally and cropping wings and stabs, but leaving the tail fully visible, something like your first (still visible) pic but cropped tighter on the left side.
Please note that this is my personal preference only, and if you choose otherwise it doesn't mean it will be automatically rejected.
Hope it helps  Smile .
Just sit back, relax and have a glass of Merlot...enjoy your life!
flynavy
Mon Feb 11, 2008 4:42 pm
I tried a 4 by 3 ratio crop. I think this is what you guys are trying to get at:
Big version: Width: 1024 Height: 768 File size: 530kb
That being said, leveling photos here in Atlanta can sometimes be difficult since the field is so random in terms of horizons and false horizons. In terms of leveling, how does she look?
acontador
Mon Feb 11, 2008 5:01 pm
Hi Chris,
Looks much better for my taste, 4:3 ratio usually works well with this kind of crops. Level seems also fine to me, only issue I see is a slight softness, which gets more pronounced towards the rear of the fuselage.
flynavy
Mon Feb 11, 2008 6:50 pm
How's this?
http://www.airliners.net/addphotos/big/ready/N828MH_1.jpg
Users browsing this forum: dvincent and 1 guest
