SNATH
Some (More!) Pre-screening Requested!
Mon Feb 11, 2008 10:08 pm
Hi all,
I finally found some time to edit these. I have no experience in getting shots like these accepted... Some feedback will be most appreciated!
BTW, for info I've tagged military and preserved on both, and nose on the second one. Is that correct?
Thanks again for all the help!
Tony
PS Walter, I hope you like the tighter crop on the KC-135A!
[Edited 2008-02-11 14:11:28]
[Edited 2008-02-11 14:19:11]
Nikon: we don't want more pixels, we want better pixels.
klintrepid
RE: Some (More!) Pre-screening Requested!
Mon Feb 11, 2008 11:23 pm
Both look good to me. Maybe a VERY small amount of sharpening. I don't see anything else.
~its a JEEP thang~
acontador
Tue Feb 12, 2008 1:09 pm
Hi Tony,
The first one looks like it would benefit from some CCW and some sharpening, and the second is a tad too bright and could also use a bit more sharpening.
Hope it helps  Smile .
Just sit back, relax and have a glass of Merlot...enjoy your life!
walter2222
Tue Feb 12, 2008 1:46 pm
Quoting SNATH (Thread starter):
Do you mean that, because they are not shot through a window, Tony?  Smile
Sure, Tony! I also liked them when the crop was not so tight, but now it more as A.net wants them. I agree with the others that they could use some selective sharpening (but I am not the right person to tell you this, because my rejection list is full with "under-sharp" shots  Smile...
Good luck, Tony!
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
ptrjong
Tue Feb 12, 2008 1:52 pm
You shouldn't tick NOSE because that's only for airliners.
Peter Smile
SNATH
Tue Feb 12, 2008 2:20 pm
Hi guys, thanks very much for the feedback!
Quoting Acontador (Reply 2):
Yeah, I was not quite sure got to level it. Could you give me an idea of what to use as a guide for leveling?
Quoting Walter2222 (Reply 3):
 Smile Hey, not all my pictures were shot through a window! Just the majority.  Smile
I also think so too.
Quoting Ptrjong (Reply 4):
Oh, is that right? Thanks for bringing this up. I'll read the rules for carefully when I re-upload.
Quoting Klintrepid (Reply 1):
and some sharpening
OK, I get the idea!  Smile I'll try to resharpen and resubmit. It's just that I was battling jaggies all the way...
Tony
ptrjong
Tue Feb 12, 2008 2:52 pm
Quoting SNATH (Reply 5):
What I'd try is treat as horizontal the path or long shadow below the green nosewheel door in the background.
Oh, and I'd add a little bit more sharpening Wink
Peter Smile
acontador
Tue Feb 12, 2008 2:53 pm
Hi Tony,
Well, this is a wide angle shot (I suspect), so you would expect both edges to 'lean' towards the center. I cannot see any clear and big enough reference in the center of the picture, but by looking at the edges it seems to me that the left one is leaning much more then the right one, thus some CCW would correct it. I think you're going to have to rotate until it 'feels' right, that is both edges leaning roughly same angle.
SNATH
Tue Feb 12, 2008 4:03 pm
Quoting Acontador (Reply 7):
Yep.
Quoting Ptrjong (Reply 6):
OK, this is useful feedback. I'll try.
Yes, we'll see whether what "feels right" to me matches what "feels right" to you.
Walter, you see whyI like window shots? There's usually a horizon that's very helpful when levelling.
Oh, really?
Tony
[Edited 2008-02-12 08:05:19]
Users browsing this forum: shattuckb02 and 6 guests
