roni957
I Need Help With My New Canon 40d
Tue Feb 12, 2008 1:30 pm
Hi everyone, this is my first post. I have bought a canon 40d but i would like someone could help me saying what kind of configuration should i have for spotting. Any help should be appreciate. Thank a lot
leadingedge
RE: I Need Help With My New Canon 40d
Tue Feb 12, 2008 2:13 pm
Would suggest.
Centre weighted Average Metering
AV mode for jets
TV for turbo props with engines running, shutter speed below 300th/sec
AI servo mode
Auto focus with centre spot selected.
colour space SRGB
Colour, sharpness etc set to Zero
Noise reduction off
Lens cap off.
ISO100,200 or 400 depending on the conditions, the lower the number the better.
Hope that helps.
JakTrax
Tue Feb 12, 2008 4:15 pm
Quoting LeadingEdge (Reply 1):
AV mode for jets
AI servo mode
colour space SRGB
Noise reduction off
Lens cap off.
Depends on the conditions. The above seem, in the main, sensible for sunny weather. I actually set my colour saturation to +1 and sharpness to +3, although everything else gets left at 0. I also use a combo of evaluative and centre-weighted metering depending on where the subject is and what the backdrop/surrounding looks like.
Yep, lower the better for less grain but don't forget the 40D's ISO goes up in increments, i.e. 100, 125, 160, 200, 250, 320, etc. (actually equal to available shutter speeds), which offers far more control. For pin-sharp images I'd recommend not going above 250.
Karl
waketurbulence
Tue Feb 12, 2008 5:09 pm
Quoting Roni957 (Thread starter):
That is a question that can only be answered in general terms. I would read through the manual a few times, know all the camera controls, and go out and test to see what brings out the best results for you. Just don't shoot in auto! Big grin
Quoting JakTrax (Reply 2):
sharpness to +3
Just wondering, why? I understand that it will sharpen the originals a tad, but why would you not want to control it 100% in PS?
-Matt
leadingedge
Tue Feb 12, 2008 5:33 pm
Quoting WakeTurbulence (Reply 3):
sharpness to +3
Me too, do you not risk adding noise unecessarily for example. If you have the right settings, a steady hand and a reasonable lens, you should be sharp enough at a setting of zero- Surely?
roni957
Tue Feb 12, 2008 6:05 pm
Thank you very much. I will test your advices.  Wink
jid
Far better letting PS do the sharpening and colour adjustment, it is far better at it than a 40D will ever be. If you shoot RAW it makes no difference what you have them set to as you can change those settings in post processing.
Jid
G7EPN is back after 15 years! Operating all Bands 80mtrs -> 70cms QRZ DX
roni957
Tue Feb 12, 2008 6:16 pm
¿Why to use SRGB if RGB can get more information ? I have read in SRGB mode images loose information about colors.
raoulr
Tue Feb 12, 2008 7:10 pm
There was a discussion going on dpreview regarding these intermediate ISO settings.
http://forums.dpreview.com/forums/read.asp?forum=1019&message=26230272
It is a bit of a technical story, but the bottom line is to avoid ISO settings 125, 250 and 500. Just FYI.
Raoul
roni957
Tue Feb 12, 2008 9:03 pm
Raoulr, very interesting discussion. Thank you for this link
warbirdz
Tue Feb 12, 2008 9:08 pm
Just make sure now that when you submit the images, you use the names of the people as the photographer that helped you, seeing as you couldn't spend the time working it out yourself.
 Wink
leadingedge
Wed Feb 13, 2008 12:12 am
Quoting Roni957 (Reply 7):
Most if not all PC Monitors will only display SRGB so unless you plan to print your images there is no point in using a wider colour gamut such as Adobe RGB. I f you do want to make prints then use a wider gamut but convert your web images to SRGB.
JakTrax
Wed Feb 13, 2008 5:31 am
It's actually a kick-back to my old slide days - I own Photoshop and I use it when I upload the odd shot here (I've only 67 in the database) but other than that I don't like it. My images are primarily for my own satisfaction and I don't normally edit them in any way. I'm aware that most leave the settings at neutral and process post-capture. As for unnecessary grain it's never been a problem - I've never had a 'grainy' reject.
Quoting Raoulr (Reply 8):
I tend to stick with 100 or, occasionally, 200 but I have used the 'in-betweens' and don't see any difference. Maybe there is one but it's certainly hard to see! I have a few pics here taken with ISO125, 160 and even 250.
Karl
jid
Wed Feb 13, 2008 7:53 am
Quoting JakTrax (Reply 12):
Karl
Karl go with the ISO that gives you the shutter speed you require. You will notice very little difference between ISO100 and 250 even up to 400!
spoogle
Wed Feb 13, 2008 8:36 am
Quoting Jid (Reply 13):
Hmmm .. personally ive noticed a difference in using either 125 or 160 , it does look like more noise than at 200 !
i may be going mad , but im sure its the case
It does refer to that in the dpreview so why have the in betweens ?
Steady hand ...... thats the way forward ( or IS )
regards
[Edited 2008-02-13 00:41:40]
Its not what you have ... its how you use it :@)
Stealthz
Wed Feb 13, 2008 8:48 am
There is a fixation, especially within this community, about low ISO but it is much better to have a sharp shot with a little noise than blurry image that is irrecoverable.
Learn the factors affecting the image and apply them appropriately!
jid
Wed Feb 13, 2008 9:03 am
Well I have not noticed that Mr Spoogle. I only use the 40D in RAW mode and have used the intermediate ISO's quite a few times due to MAN's not always great weather. These two were shot at ISO160
Photo © Jid Webb
Photo © Jid Webb
No noise reduction used in post processing.
Samuel32
Wed Feb 13, 2008 10:07 am
Wow,
I almost always use ISO 125 on my 40D when I got the 100-400L on there because it needs a lot of light which isn't always present. I've haven't noticed any significant noise at it, but if its true that ISO 160 is less grainy in shadows and so on, I'll be glad to use ISO 160 instead of 125.
I'll start testing today.
JakTrax
Wed Feb 13, 2008 5:42 pm
Quoting StealthZ (Reply 15):
I like it! Good comment. My point exactly, but you worded it better.
Quoting Jid (Reply 16):
Nope, me neither. Was out at MAN today, light first thing was nice but soft (08:05). ISO100 gave me 1/250, but ISO125 gave me 1/400. I went with the latter. As Jid suggests I use whichever ISO gives me the shutter I want, and I really cannot see any problems with the intermediate ISO settings.
Karl
