LHSebi
Upload Not Working? (and Prescreen)
Tue Feb 19, 2008 11:08 am
Hello all,
I have been absent from uploading photos from this site for a while, and thought it might be nice to start again. I have some upgraded kit, and went for a first hour or so to DUS to test it, and see what I could get. Turns out I need to get back into it  Wink, but some turned out ok, at least I thought so!
I wanted to upload them, but for some reason the auto complete didn't work with me, and when I then wanted to manually select the country, the menus were almost empty, apart from 2 or 3 options including "other airport"... am only I having this problem? The selection of the aircraft didn't work properly either...
While I'm at it, I was wondering if my shots were up to par with the current new standard! I would appreciate a comment or two on the following shots, see if they're worth uploading!
D-ABGH
EC-HGS
I-EXMB
D-AGEL
Thanks to all!
Sebastian
I guess that's what happens in the end, you start thinking about the beginning.
Samuel32
RE: Upload Not Working? (and Prescreen)
Tue Feb 19, 2008 11:19 am
Sebastian,
I got the exact same problem at the momment. Nothing works at the momment, hope it gets fixed soon.
Prescreen:
First three can use a bit more contrast.
Last one has a color problem. Fiddle around with the color balance, I'm guessing less green/yellow and more blue.
Sam,
747438
Tue Feb 19, 2008 11:24 am
Photo Display Not Working, Again (by Sandyb123 Feb 19 2008 in Site Related)
Not exactly confidence inspiring.
