CaptainDanieL
Converting CR2 To JPG Help Please?
Sat Feb 23, 2008 5:44 pm
Hello  Smile !
Could someone please tell me where I can find a freeware program to convert CR2 images into JPG. I have taken hundreds of photos in CR2 format on my Canon 400D and could only find a program that allows me to change 5 at a time, which would take me forever.
Thanks in advance,
CaptainDanieL  airplane
jetmatt777
Support
RE: Converting CR2 To JPG Help Please?
Sat Feb 23, 2008 5:58 pm
Your 400D should have came with the software to do it, "Digital Photo Professional" I think it's called, it came with my 400D.
I shoot in RAW + JPEG, and when I see a JPEG file that looks good enough to edit, I open the CR2 up into the RAW converter. It takes alot of CF card space, but it gives you a preview of what images look good and others that you could do without.
-Matt
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
oly720man
http://www.faststone.org/FSViewerDetail.htm
from
http://www.dpchallenge.com/forum.php...action=read&FORUM_THREAD_ID=623655
includes.......
Configurable batch processing to convert/rename large or small collections of images
and
No Adware No Spyware
Free for Home Users
CaptainDanieL
Sat Feb 23, 2008 8:05 pm
Quoting Oly720man (Reply 2):
from
includes.......
Thanks Oly720man (Andrew Kennaugh) the program converted all my images with no problems at all Big grin
oly720man
Sat Feb 23, 2008 8:06 pm
Quoting CaptainDanieL (Reply 3):
Glad to be of service!!
jobu7282
Mon Feb 25, 2008 5:51 am
What program are you using? I ask because I am using CS3 and I had the same problem but I found the plug in for Adobe and I leave everything in Raw until I edit a photograph and then save it as a JPEG.
flynavy
Mon Feb 25, 2008 6:46 am
You can use Adobe's DNG converter which converts *.cr2 files into *.dng files. From there, you can open up the DNG in Photoshop without the need of the latest Camera Raw plug-in. Edit the photo as you'd like and then save it as a JPG.
I personally shoot RAW all of the time. It is an additional safety net in case I screw up my camera settings. I had to get the latest version of Camera Raw for CS3 when I bought my 40D as well.
Change is: one airline, six continents!
whisperjet
Screener
Mon Feb 25, 2008 6:57 am
What sense does it make to convert all images to jpg at the same time?
Imo shooting in RAW makes only sense if you adjust the settings of each picture individually...  Confused
Stefan
Nobody is perfect - not even a perfect fool.
paulinbna
Mon Feb 25, 2008 7:24 am
Quoting Whisperjet (Reply 7):
That is exactly my thoughts if you are going to do that you might as well shoot in L JPEG and save the space. I am
 confused
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
sulman
Mon Feb 25, 2008 10:54 am
Stefan,
Using DPP I frequently make the changes I want to a series of images, then batch convert them. I find this easier for my workflow, rather than doing it one image at a time.
James
Users browsing this forum: scbriml and 10 guests
