KLM772ER
Contrast Rejection, Worth An Appeal?
Wed Feb 27, 2008 7:19 pm
Hello,
I got this one rejected for contrast only today and I am thinking of appealing it. Is it worth a try or?
The shot was taken during the evening hours short before sundown...
http://www.airliners.net/addphotos/rejections/big/20080227_S5-AALVenghaus1.jpg
What do you think??
Björn
[Edited 2008-02-27 11:20:21]
Stil
RE: Contrast Rejection, Worth An Appeal?
Wed Feb 27, 2008 7:49 pm
Hi, Björn
I've got a lot of "contrast" rejections lately, the last one with similar histogram than yours. It seems to me A.net screeners agreed a new standard regarding contrast. I think i'm beginning to understand this and it seems your shadows are too dark. They doesn't show any detail.
As in some of my rejections, it shows the moment light, as you remarked it was taken during sunset; but this dark shadows doesn't seem to be welcome here.
My advise is you'll have to start a new edit...
Good luck with it.
Stil
....... Gueropppa! ......
LHSebi
Wed Feb 27, 2008 10:58 pm
If you have the original RAW, I would bump up the shadows a bit to lighten up the underside of the aircraft. Otherwise, I'm almost certain you'll get a baddark rejection, sorry... Definitely don't appeal.
I guess that's what happens in the end, you start thinking about the beginning.
bubbles
Crew
Wed Feb 27, 2008 11:28 pm
Quoting KLM772ER (Thread starter):
No. The rejection is correct. I don't think this shot could be accepted in appeal process.
_Hongyin_
Lanas
Thu Feb 28, 2008 12:29 am
Hi Björn
Nice pic, but Stil has it right: the shadows show no detail. I also would put the aircraft a little higher in the frame.
Good luck on your next try.  thumbsup
Cheers  Smile
Lanas.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
dvincent
Thu Feb 28, 2008 1:50 am
I wouldn't say the shadows aren't holding detail - it's still there. Just that they're too dark.
From the Mind of Minolta
dendrobatid
Thu Feb 28, 2008 6:49 am
Quoting Dvincent (Reply 5):
Dan has it spot on !
I think that the overall quality looks good with the detail just being present but too dark. A little lift on the curve would probably rescue it unless it gets too noisy.
One other thing though......
If you look between the dark line of shadow under the fuselage and the white of the top of the fuselage, that 'band' is rather yellow and I think that the image needs a bit of blue adding too, just a few units in the mid tones.
Mick Bajcar
KLM772ER
Thu Feb 28, 2008 7:51 am
Hello all,
Thank you for your responses and help, here is the picture with a little curve adjustment and added a very little blue (I am still not really convinced of it, as it was a low sun, and they tend to be a little more yellow  Wink )
http://www.airliners.net/addphotos/big/ready/S5-AALVenghaus2.jpg
Any better??
Björn
cpd
Thu Feb 28, 2008 11:55 am
Quoting KLM772ER (Reply 7):
I think it is still very dark under the wings overall, and it probably wouldn't make it because of that. Sorry.
Chris.
[Edited 2008-02-28 03:56:24]
KLM772ER
Fri Feb 29, 2008 10:06 pm
Hello,
I have another one, what do you think of it? Got rejected for contrast and dark.
http://www.airliners.net/addphotos/rejections/big/20080229_A6-EBGVenghaus8.jpg
björn
[Edited 2008-02-29 14:11:12]
LHSebi
Fri Feb 29, 2008 10:53 pm
Sorry... I'm guessing it won't make it since it looks as though it only has one main landing gear... nice shot though.
Sebastian
KLM772ER
Fri Feb 29, 2008 11:11 pm
Quoting LHSebi (Reply 10):
If you only see one main landing gear, than either mine or yours monitor seem to be way off regarding the contrast....
And I didn't change anything and also don't see any difference to before...
So anyone else only seeing one main gear in the shot? I am getting a bit concerned right now....
Björn
LHSebi
Fri Feb 29, 2008 11:17 pm
I was exaggerating, but I think you see my point. There is a very large and very dark shadow underneath the aircraft which I assume was the rejection reason!
eadster
Sat Mar 01, 2008 2:28 am
Quoting KLM772ER (Reply 11):
No I can easily see it. So why dark? because of the shadow? If so that's pretty lharsh isn't it?
I'm not understanding where Anet come from with contrast rejections sometimes. Some explanations would be great on it.
I don't wanna take over the thread but I got a dark and contrast on this....
http://www.airliners.net/addphotos/r...ctions/big/20080227_VH-ANO3feb.jpg
dendrobatid
Sat Mar 01, 2008 7:01 am
Quoting Eadster (Reply 13):
The rejection text is actually a pretty good description of the problem but the two examples Bjorn gives here are fairly representative of one extreme of the commonest problem. Sebastian was evidently being a little sarcastic, humourous, but he was also making a point. Look at the starboard undercarriage and, yes, that is there, but what about the tyres ? They have disappeared into the shadows and it is that that causes me to agree with the contrast rejection. The dark rejection ? I am not sure that I agree with that part though sometimes just brightening an image can restore that shadow detail. It maybe justified and the two often go together as it can be difficult at times to separate the problems without changing them.
In good old-fashioned photographic terms, not airliners.net rules, generally
1, Every image should have a pure black
2, Every image should have a pure white (failing on 1 or 2 leaves flat, muddy images)
3, Details should be held into the shadows and highlights (neither blocked up)
Bjorns fails on the last point with no detail being held into the shadows = valid contrast rejection.
No 1 is by far the commonest rejection reason where images have weak, smoky looking blacks that are effectively a very dark grey. If levels are opened on these images (Ctrl+L) there is usually a gap on the left of the histogram and moving the left slider in corrects the problem. If an image of mine shows the problem I move the left slider in whilst watching the blacks and stop at the point the blackest part loses its smokiness.
Incidentally, images with weak contrast tend to appear softer and those with high contrast tend to show oversharpening more so getting the contrast correct is a very important stage of getting your image right.
I hope this helps
Mick Bajcar
KLM772ER
Sat Mar 01, 2008 9:12 am
Thank you Mick, that clarified a lot (at least for me  Wink )
I will rework the EK shot soon and give it another try as I really like it especially with the anti tail strike device so clearly visible  Wink
Just one more question to all of you, is the CRJ really still to dark at the underside? As far as I see it and understand the above written it now looks ok to me than!
Björn
KLM772ER
Wed Mar 05, 2008 7:20 pm
Hello,
here are both shots in a new edit:
http://www.airliners.net/addphotos/big/ready/A6-EBGVenghaus10.jpg
http://www.airliners.net/addphotos/big/ready/S5-AALVenghaus3.jpg
Are they any better or still to much contrast?
Björn
dvincent
Wed Mar 05, 2008 8:51 pm
Björn:
I'd say they're much better. Whether a screener thinks so might be different.
acontador
Thu Mar 06, 2008 7:34 pm
Hi Bjoren,
Both edits are still rather dark in the midtones. If you go to the histogram and move the middle slider to about 1.20 you'll see the difference...however, be careful with the eventual grain and contrast issues when increasing the midtones.
Hope it helps  Smile .
Just sit back, relax and have a glass of Merlot...enjoy your life!
KLM772ER
Thu Mar 06, 2008 8:49 pm
Thanks Andrés!
I deleted them from the queue.
Here is another edit of the T7:
http://www.airliners.net/addphotos/big/ready/A6-EBGVenghaus12.jpg
It is a complete new edit from the start and I think it is much better now (Glad I shot raw  Wink )
The CRJ will follow as soon as I have a place in the queue  Wink
Björn
KLM772ER
Fri Mar 07, 2008 7:40 am
And here is the new version of the CRJ:
http://www.airliners.net/addphotos/big/ready/S5-AALVenghaus4.jpg
Björn
Users browsing this forum: eggohoek, miamivice and 1 guest
