ac888yow
Help Me Level This Would Ya?
Thu Feb 28, 2008 3:33 pm
This shot got the diss last night for level. To be honest I kind of expected it because I've never been good at levelling these banking shots.
http://www.airliners.net/addphotos/rejections/big/20080227_IMG_2252_TS_CGSAT_021708_SXM_InFlight.jpg
Can someone suggest a point of reference to use for levelling? Originally I tried using that V-shaped building above the wing.
Thanks for any help.
KLM772ER
RE: Help Me Level This Would Ya?
Thu Feb 28, 2008 3:43 pm
Hello,
I would say it needs some CW - Rotation with the main weight on the masts of the sailboats as they are in the center of the image and the building you used is supposed to be leaning a bit, as the image hast some wideangle distortion!
Hope this helps!
Björn
[Edited 2008-02-28 07:52:23]
GUAMVICE
Thu Feb 28, 2008 3:57 pm
Quoting KLM772ER (Reply 1):
For an image like this, use your center verticals (you're lucky you've got some)... good luck, nice image!
The two most engaging powers of a photographer are to make new things familiar and to make familiar things new. ~Thacker
ac888yow
Thu Feb 28, 2008 4:23 pm
Using the ship masts I get some seemingly absurd rotation value of 8 - 8.5 degrees. This essentially eliminates most of the picture when cropping.
Using some of the buildings in the center I get a value around 4.5 - 5 degrees. This seems more 'reasonable', but the ship masts will not be perfectly vertical in this situation.
Can someone play around and lend me a hand using this (highly compressed) original? Thanks again.
Big version: Width: 3504 Height: 2336 File size: 272kb
KLM772ER
Thu Feb 28, 2008 4:38 pm
Just a very quick play:
I rotated the picture 5.55° CW and this is for me the best compromise of looking level and cropping... Don't know if it would be acceptable this way, but I would add a comment to the screener explaining why leveled this way and hope the best  Wink
Big version: Width: 1024 Height: 683 File size: 556kb
Hope to see it in the db, it is a nice photo!
Björn
ac888yow
Thu Feb 28, 2008 4:47 pm
Thanks Bjorn. Looks good to me. I'll try that and we'll see what happens.
SNATH
Thu Feb 28, 2008 4:58 pm
I think it needs a bit more than 5.55 CW. Here's with 6.5 CW:
http://www.airliners.net/photos/misc/uf/536884224/phpEopim7.jpg
Tony
Nikon: we don't want more pixels, we want better pixels.
KLM772ER
Thu Feb 28, 2008 5:07 pm
Quoting SNATH (Reply 6):
To make it complete level I would agree that it needs a bit more rotation! But than the crop gets a bit to tight for the picture IMHO that is why I think a little less is more in this case  Wink
And as it is a wide-angle shot there is some distortion anyway I think it is ok for this one...  Wink
Björn
Psych
Thu Feb 28, 2008 5:29 pm
Hello Peter.
I really feel for you here, as I like the photo. Unfortunately I reckon this needs about 10 degrees  Wow! of rotation to make it level.
Big version: Width: 700 Height: 526 File size: 276kb
Peter's Photo
I think that the examples above still look in need of further rotation and thus some screeners may still not be satisfied.
I began by simply rotating according to what my eye suggested to me would be where the horizon would be, if the top of the photo was extrapolated upwards. Then with closer examination in the area of the middle of the photo - particularly that large hotel with clear verticals - I ended up with this amount. But it looks as though this will not be possible to crop acceptably.
All the best.
Paul
bubbles
Crew
Thu Feb 28, 2008 5:45 pm
Quoting KLM772ER (Reply 4):
Yes, I would agree. Roughly that looks good.
Big version: Width: 700 Height: 506 File size: 408kb
Rotation
Quoting Psych (Reply 8):
Unfortunately I reckon this needs about 10 degrees of rotation to make it level.
10-degree CW rotation is way too much.
_Hongyin_
ac888yow
Thu Feb 28, 2008 6:13 pm
Thanks to all for their input.
Quoting Bubbles (Reply 9):
Hongyin, you've rotated the original (already rotated) image by 5.55 degrees, whereas Bjorn used my original and rotated that a true 5.55 degrees.
Could I trouble you to clarify whether or not Bjorn's example looks acceptable? Feel free to play with the original if you have a moment.
Psych
Thu Feb 28, 2008 6:31 pm
Quoting AC888YOW (Reply 10):
So does that mean my estimate of 10 degrees was in fact not that far off?  wink
I am now pretty confused too! The images in Hongyin's and my post look roughly the same to me. Well - what's a mere 5 degrees between friends  biggrin . It certainly makes a change to be debating this, rather than the usual 0.2 or 0.3 degrees.
All the best.
Paul
ac888yow
Thu Feb 28, 2008 6:52 pm
Quoting Psych (Reply 11):
I guess not. Neither was my estimate of 8-8.5 degrees either  Wink
But I must say I have difficulty accepting the fact that this thing needs 8-10 degrees of rotation to get level. At the worst of times the most I've ever been off was about 3 degrees. If I was a complete idiot when taking this shot resulting in a 10 degree slope maybe I should consider selling my camera and changing hobbies.
Continued discussion is welcomed and appreciated.
SNATH
Thu Feb 28, 2008 7:13 pm
Quoting KLM772ER (Reply 7):
I understand, but it's leaning distractingly (is there such a word!!!!) to the left.
Sure, but both sides are leaning to the left; due to the wide angle lens, one side should have been leaning to the left and the other to the right.
I feel that this is going too far. The right side of the pictures looks as if it's about to be "poured" out of the right border.  Smile
Yeah, I'm confused too.
Tony
ac888yow
Thu Feb 28, 2008 7:26 pm
I'm working on an edit that uses a 6.05 degree CW rotation of the original. I think It looks pretty good. I'll post it when I'm done.
KLM772ER
Thu Feb 28, 2008 7:35 pm
Quoting SNATH (Reply 13):
As said, I agree they are both not leaning the same amount, but they are not leaning to the same site....
Big version: Width: 1024 Height: 683 File size: 124kb
Just some lines along some verticals (yes they are rough and can be off about 2 degrees, but they show the tendency...)
And the aircraft is in a bank, and it is photographed in an angle out of the window, and therefor I rather like the verticals in this one a bit off (as they eye is fooled in a way by the angle anyway) than cropping to much of the landscape, which is IMHO what makes the picture!
As said it is not 100% level, but the best compromise for me..
Björn
ac888yow
Thu Feb 28, 2008 7:59 pm
Here's another edit:
http://www.airliners.net/addphotos/big/ready/IMG_2252_TS_CGSAT_021708_SXM_InFlight_Re.jpg
Psych
Thu Feb 28, 2008 8:02 pm
Quoting AC888YOW (Reply 12):
You do yourself a great disservice there Peter in my opinion. By the look of the bank angle, your 'frame of reference' is seriously off level in the first place. You have the aircraft angled relative to the horizon due to the climb, and then you have the angle due to the bank. That would mess things up badly for the best of us trying to get an 'A.net level' photo wink .
All the best.
Paul
ac888yow
Thu Feb 28, 2008 8:12 pm
If it wasn't totally obvious I was just joking around about the selling camera/changing hobbies bit. I was making fun of myself and my abilities if the best I can do results in being off angle by 10 degrees!
And you're right about the bank angle. It is quite steep. Anyone who has observed departing aircraft at SXM and experienced the departure themselves knows what I'm talking about.
bubbles
Crew
Thu Feb 28, 2008 9:02 pm
Hi Peter
Just did a very quick rotation and crop.
Big version: Width: 800 Height: 533 File size: 352kb
AnotherTry
_Hongyin_
ac888yow
Thu Feb 28, 2008 9:50 pm
Thanks Hongyin. The angle on yours seems pretty darn close, if not identical, to my latest effort. I'll leave it in the queue and see what happens.
SNATH
Fri Feb 29, 2008 7:03 am
Quoting AC888YOW (Reply 16):
Levelling-wise, I think this is the best out of all the previous attempts. Great shot too! Good luck!
Tony
Psych
Fri Feb 29, 2008 7:32 am
I have been very interested reading this thread, and have come to the original anew this morning.
This is my revised attempt, as I still get preoccupied (rightly or wrongly) with that large hotel in the top centre area of the photo:
Big version: Width: 1024 Height: 683 File size: 553kb
Peter's Revised Image
Whichever way you go with this one, Peter, I wish you all the best. I hope you are right, and I am wrong, because I think the photo is enhanced by including the whole of that flap fairing that I have had to crop. It is a horrible one to get just right and I hope the screeners give you a sympathetic hearing.
Just one further point - I found the example you posted in Reply 16 slightly dark - I refer particularly to the top left hand area of the image.
Good luck.
Paul
ac888yow
Thu Mar 06, 2008 3:57 pm
Just an update:
My re-submission has been accepted. I won't plug it, but you can obviously search for it if you want.
Thanks to all for your help.
- Peter -
SNATH
Thu Mar 06, 2008 3:59 pm
Quoting AC888YOW (Reply 23):
I won't plug it
I will!!!
Photo © Peter Tsagaris - CYOW Airport Watch
Great shot and congratulations!
Tony
Psych
Thu Mar 06, 2008 6:52 pm
Very well done there Peter - this is a photo that deserved to be accepted.
All the best.
Paul
Scotland1979
Fri Mar 07, 2008 10:39 pm
Great shot!
Nice to see it in database!
Frank
Jesus said "I am the Way and the Truth and the Life. No one comes to the Father except through Me" - John 14:6
Users browsing this forum: acontador, Dfthu and 1 guest
