derstatic
Centered?
Fri Feb 29, 2008 5:30 pm
Obviously not! However I don't know in which direction I should move it. IMO it's quite centered, maybe a tiny bit too high in the frame. Please give some feedback!
http://www.airliners.net/procphotos/...20080229_Kastrup080219_008_JB1.jpg
Psych
RE: Centered?
Fri Feb 29, 2008 5:34 pm
Joakim.
I think the screener felt the aircraft was slightly high in the frame. Was that the only rejection reason given? I ask because I see slight oversharpening of the cheat line and also quality issues in the fuselage - take a look in the blue area just above the engine - a bit like jpeg compression. Contrast is very tricky too in such lighting conditions.
All the best.
Paul
derstatic
RE: Centered?
Fri Feb 29, 2008 7:42 pm
Yeah, centered was the only reason. The jpg compression is strange, because I shot this one raw, and worked it in photoshop.
Scotland1979
Crew
RE: Centered?
Sat Mar 01, 2008 1:28 am
Quoting Psych (Reply 1):
At what dpi are you using? 300? I did lower than 300 to reduce cheatline. Did you?
Jesus said "I am the Way and the Truth and the Life. No one comes to the Father except through Me" - John 14:6
derstatic
RE: Centered?
Sat Mar 01, 2008 7:52 am
Yeah I believe it's 300, I haven't actually found the number in Photoshop but I recall that 300 is default setting isn't that right? And I haven't changed the resolution.
derstatic
RE: Centered?
Sat Mar 01, 2008 9:09 am
Continuing this thread. Had the second shot of my session rejected at second screening for contrast and level. Any ideas? Didn't know it had to be level when there's no horizon. The planes do land with a slight nose up angle obviously, which this photo shows. Can I do anything about the contrast stuff? Shot it raw. And does the level rejection make any sense when there's no horizon in the picture? IMO, it doesn't, naturally the horizon should be horisontal, it's in the nature of the wording, but this?!
http://www.airliners.net/procphotos/...20080301_Kastrup080219_007_JB3.jpg
Users browsing this forum: JakTrax and 1 guest
