spencer
Colour Rejection Help Please.
Mon Mar 03, 2008 8:51 pm
I received a colour rejection on the below image. I'm looking for suggestions as to what I could do to improve the COLOURS and/or COLOUR CAST. It's not the greatest scan, I'm only just learning how to scan to tell the truth, so let's keep any suggestions this time to the rejection reason please.
http://www.airliners.net/addphotos/r...ns/big/20080301_UPS747Fsjw.jpg.jpg
TIA
Spencer.
JeffM
RE: Colour Rejection Help Please.
Mon Mar 03, 2008 8:56 pm
Quoting Spencer (Thread starter):
..remove the dingy yellow tint.
whappeh
Mon Mar 03, 2008 9:02 pm
Get rid of the tint:
http://img230.imageshack.us/img230/1416/showxr0.jpg
I can tell you how I did it, if you want to know via PM or something (if what I did is even correct, lol)
-Travel now, journey infinitely.
garry
Mon Mar 03, 2008 9:15 pm
Hi Spencer - it's not too difficult to remove. The key is getting the Info palette open in Photoshop (assuming you have it)
Here's how I removed it:
Make a threshold layer select white point and black point - you will see when doing this there is a colour cast as the RGB from the Info palette are not equal. Either use Curves or Levels, select white eye dropper and drop it on the white point you found from Threshold. Do same for Black point. This just about removes the cast.
There was also a cast in the mid tones - so I found a neutral gray and again using either Curves or Levels selected the grey/mid eye dropper and selected the point.
The key is making sure when you have a black/white or mid grey the Info palette shows the same values for each of the R, G and B channels.
HTH
Garry
www.garryridsdale.com
garry
Mon Mar 03, 2008 9:45 pm
Sorry Spencer - here's the result of my attempt as outlined above
Big version: Width: 1024 Height: 698 File size: 690kb
spencer
Tue Mar 04, 2008 11:27 am
Thanks very much for all the help/suggestions. Appreciate it a lot. I'll have another bash at it from scratch and see how I fair. Cheers.
Spencer.
