khelmDTW
Cannon Power Shot; Thoughts?
Tue Mar 04, 2008 7:50 am
I am entertaining the idea of purchasing the Canon PowerShot S5 IS Digital Camera. Its a good buy at $350, I chose it because of its Shutter speed range, High resolution, ability to manually focus, and that really cool LCD.
So my question to you is...
If anyone here has this camera, what do you think?
And to all of you photo-files out there, is this a good first quality camera?
Here is a good link to Tiger direct with a bunch of specs and a video.
Let me know what you think.
Kevin
"Labor is prior to, and independent of, capital. Capital is only the fruit of labor, and could never have existed if labor had not first existed. Labor is the superior of capital, and deserves much the higher consideration"
Kukkudrill
RE: Cannon Power Shot; Thoughts?
Tue Mar 04, 2008 8:13 am
It's as good as you can get short of a DSLR. Under favourable light conditions it should give you a.net quality (if that's what you're after), subject always to the need to post-edit photos using Photoshop or similar high-powered editing software. You should do well with the S5.
Charles
Make the most of the available light ... a lesson of photography that applies to life
viv
Tue Mar 04, 2008 9:00 am
The S5 is one of the best non-SLR compact digital camera available - the very best is the Canon G9.
Used correctly, it is capable of very good results, limited only (as are all compact digital cameras) by the small sensor.
[Edited 2008-03-04 01:02:44]
rleiro
Tue Mar 04, 2008 10:20 am
I am very happy with my S5 Powershot:
Photo © Roberto Leiro - SVZM Fotografos.
If you go for it, I recommend you the 1.5x extender and the 58 mm lens.
Roberto.
A proud SVZM Spotter!
spencer
Tue Mar 04, 2008 11:31 am
I can only compare it to the G9, as that's the one I have. It's outstanding to say the least, the very least in fact! I have had a couple of shots uploaded with it and at 12mp it's a great camera to take on your hols along with or even instead of a DLSR.
Photo © Spencer Wilmot
Spencer.
