whappeh
Soft Lenses?
Tue Mar 04, 2008 8:35 pm
I've been having a conundrum lately with one of my new lenses. I got the 18-200VR at Christmas, and was very happy to pick it up. However, it seems EVERYTHING I shoot with it is soft as soft can be. Far much more so then my 18-70 that was the kit lens I was using before hand. I'm just curious, how can you really tell if its a lens problem, or is the lens naturally soft? If it is a problem with a specific lens, can you do anything about it? Send it to Nikon? Warranty?
-Travel now, journey infinitely.
ruudb
RE: Soft Lenses?
Tue Mar 04, 2008 9:37 pm
I think it is typical for these kind of lenses with a long reach, also it has a lot of vignetting, at least the sample I used. To be honest that was a bigger problem to me as being soft.
whappeh
RE: Soft Lenses?
Tue Mar 04, 2008 9:41 pm
I haven't had much vignetting issues, atleast none that stood out worse to me then the overall softness. I'm having to do so much extra sharpening to my photos in post-processing, its damn near making them unusable.
777MechSys
RE: Soft Lenses?
Tue Mar 04, 2008 11:40 pm
Quoting Whappeh (Thread starter):
The first 18-200 lenses are supposed to be good. After that they pretty much suck. I tried it out on two different bodies and noticed the same soft issues.
The 18-70 was a descent lens. I liked it better than the 18-200.
whappeh
RE: Soft Lenses?
Wed Mar 05, 2008 12:01 am
I'm really surprised by the softness... I'm going to have to do some tests in good light tomorrow with some letters and text from fixed positions and find out.
JeffM
RE: Soft Lenses?
Wed Mar 05, 2008 12:33 am
How do your prints come out? If they are acceptable at around 11x14 or slightly larger, I wouldn't worry unless you primarily display your images on the web. Trying to judge an image on a screen can be futile.
whappeh
RE: Soft Lenses?
Wed Mar 05, 2008 12:57 am
I haven't done any print work since I got the lens, only been working on shooting for anet and other digital medium. I may go make a print and find out, that could be good advice. Thanks.
preelude
RE: Soft Lenses?
Fri Mar 07, 2008 10:05 pm
It's a general rule that the more range a lens covers, the poorer the optical performance will be, however there are exceptions. 18-200 = 11.1 zoom. Also if you want sharp images you usually have to step down the lens, typical sweet spot is around f/8 to f/9, at 500mm I have to shoot f/11 with my sigma 170-500. Prime lenses seem to be sharp at all f/stops...
whappeh
RE: Soft Lenses?
Fri Mar 07, 2008 10:21 pm
With my 18-200 I always shoot at F/8 on Aperture priority (unless the situation warrants a change). I may do some jumping around the fstops and trying to find a sharper setting.
Kereru
RE: Soft Lenses?
Sat Mar 08, 2008 5:43 am
Check this out.
http://www.dpreview.com/lensreviews/...8-200_3p5-5p6_vr_afs_n15/page4.asp
I use my 18-200 on mainly walk around or close stuff.
Colin  old
Good things take Time.
Users browsing this forum: eggohoek and 1 guest
