paulinbna
Strange Rejection Reason
Tue Mar 04, 2008 10:14 pm
This is a new one for me.
Rejected for added text or graphics.
http://www.airliners.net/procphotos/...?filename=20080304_N757SS_2909.jpg
1. I did not add anything.
2 I don't see anything that could be confused with this.
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
timdegroot
RE: Strange Rejection Reason
Tue Mar 04, 2008 10:29 pm
Most likely a mistake since the color rejection is adjacent to the copyright one. It's too orange, and also a tad grainy.
Tim
Alderman Exit
sulman
Tue Mar 04, 2008 10:55 pm
I don't know about the grain (can't see it on this monitorf) but it does look like the colour temperature is in the low Kelvin range; hence the orange cast from the sodium lighting. If you've got a raw original, it's an easy fix. You could go for the ultra-high kelvin look popular here, where the sky is a deep blue, and the lights a kind of urine-yellow, but I'd leave a bit of red in there as that is probably how it actually looked.
James
Silver1SWA
Tue Mar 04, 2008 11:47 pm
Quoting TimdeGroot (Reply 1):
Quoting Sulman (Reply 2):
I'm not seeing the grain either.
JeffM
Wed Mar 05, 2008 12:36 am
Quoting Silver1SWA (Reply 3):
Quoting Sulman (Reply 2):I don't know about the grain (can't see it on this monitorf)
Everything above the fuselage is terribly grainy.
Silver1SWA
Wed Mar 05, 2008 12:59 am
Quoting JeffM (Reply 4):
Hmm...must be a monitor thing. I'm not seeing it here on this monitor at work.
paulinbna
Wed Mar 05, 2008 3:48 am
I think what grain you are seeing is that fact that there was a heavy mist in the air that night.
The problem is that the front half had white light shinning on it the back half had a sodium light shinning on it. Which part of the aircraft do I make white?
CallMeCapt
Fri Mar 07, 2008 11:05 am
Haven't been around in a while but this photo grabbed me and I'm going to throw my 2c worth.
Not sure whether screening criteria have changed regarding this suggestion.
Fix your cropping to encompass the aircraft only and not the wing area extending past the rear of the fuselage. The crop you have done leaves a kind of unbalanced look.
example.
http://www.airliners.net/photo/Qantas/Boeing-747-438/0870430/L/
Goran
Without struggle, there is no progress. (Frederick Douglass)
clickhappy
Fri Mar 07, 2008 2:15 pm
And it also needs quite a bit of CW rotation to be level.
Users browsing this forum: Newark727 and 2 guests
