eaglespirit
Corrections On A Rejected Photo
Thu Mar 13, 2008 2:11 pm
Hi,
I need your opinions about a photo which was rejected for CENTERED and OVERSHARPENED :
Rejected one :
1a. http://img301.imageshack.us/img301/3801/b737ramzh3.jpg
The new one I want to upload :
1b. http://img406.imageshack.us/img406/5194/sharpened3xv2.jpg
Is the second one OK ?
By the way, what do you think of this one ?
2. http://img72.imageshack.us/img72/1413/p7050097copie2gu4.jpg
Alex
ANITIX87
RE: Corrections On A Rejected Photo
Thu Mar 13, 2008 2:37 pm
The second is still not centered correctly. You need to move the aircraft higher in the frame (I generally place the center of the image at the windows on an angle like this (see my JFK shots in the Database).
Also, careful with sharpening, as there are slight jaggies alone the outside of the tail.
TIS
eaglespirit
Thu Mar 13, 2008 2:52 pm
Thank you TIS,
I thought the space between top of the photo and upper part of the aircraft (here the tail) should be the same as the one between bottom and lower part (here the left wing).
I will change this and try to erase the jaggies.
Alex
CalgaryBill
Thu Mar 13, 2008 3:16 pm
Quoting EagleSpirit (Reply 2):
If you use the top of the tail as your gauge, the bulk of the aircraft will be too low in the frame. Arbitrary rules like pixel counting usually don't work - the image has to look centered (perhaps a better word is "balanced").
B
Jetfreak
Thu Mar 13, 2008 6:04 pm
i think sharpness is ok now  Smile
Regards, Jetfreak
eaglespirit
Fri Mar 14, 2008 11:13 am
Thanks B and Jetfreak
B, if the image have to look centered, I have to move the aircraft to the left ? The bulk is too much on the right because of the little left wing in the empennage.
Anyway, I moved the aircraft higher in the frame, here is the result :
http://img266.imageshack.us/img266/8735/centr2tp2.jpg
And what about this photo ? Does it have a chance in Airliners.net ?
Alex
Jetfreak
Fri Mar 14, 2008 1:25 pm
Quoting EagleSpirit (Reply 5):
sorry, but it will get a motive rejection.
