upcfordcruiser
CO767 And Clear Sky - Rej For Motive?
Fri Mar 14, 2008 3:53 am
http://www.airliners.net/procphotos/...in?filename=20080313_223083611.jpg
It also got nicked for center and common. Both of which I don't disagree with after looking closer, yes it's high in the frame, I see that now. The motive part baffles me though, was it because of cropping the left wing?
CalgaryBill
RE: CO767 And Clear Sky - Rej For Motive?
Fri Mar 14, 2008 4:12 am
Quoting Upcfordcruiser (Thread starter):
Likely. It would look better if you cropped that side closer to the tail. Pretty nice shot though!
B
spoogle
Fri Mar 14, 2008 10:42 am
Quoting CalgaryBill (Reply 1):
My 1st thought to be honest ... however doing a search does reveal plenty of the same/similar crop ...
lovely shot though .
Tried the appeal function ?
regards
Its not what you have ... its how you use it :@)
cpd
Fri Mar 14, 2008 10:48 am
If you can centre it more, that will help (check distance from nose of plane to top of image, and tail of plane to bottom of image). That's my strategy for these kinds of images.
However, the common and motive rejections will seal the fate of this image I think. Motive for the crop, common for obvious reasons. Sorry.
Chris.
scbriml
Fri Mar 14, 2008 12:20 pm
Motive rejection is for the crop - either show all the wing and horizontal stabiliser, or crop right up to the end of the fuselage. Either would be acceptable, but your original crop falls between the two:
Photo © Steve Brimley
