SNATH
Can Anyone Recommend A Good Negative Scanner?
Tue Jul 08, 2008 11:55 pm
Hi all,
As the title says, I'm looking for a good-quality scanner to scan film negatives. Would anyone like to recommend one? I only did a little bit of research and I read a few good things about the Canon CanoScan 8800F. Is it reasonable?
BTW, what kind of resolution should I expect from 35mm film?
Tony
Nikon: we don't want more pixels, we want better pixels.
JakTrax
RE: Can Anyone Recommend A Good Negative Scanner?
Wed Jul 09, 2008 2:17 am
I too have been looking into this. My budget isn't crazy, perhaps £300 ($600) maximum - any chance of a (half) decent negative scanner for this or am I dreaming? Don't know much about scanners.....
Karl
SNATH
Thu Jul 10, 2008 4:02 am
Quoting JakTrax (Reply 1):
I was actually looking to spend less!!!
Tony
walter2222
Thu Jul 10, 2008 5:00 am
I am using the Canon 8400F (cheap flatbed scanner). Not the best scanner, but sufficient to get scans accepted here (if the originals are reasonable).
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
oly720man
Thu Jul 10, 2008 9:19 am
I use the Canon Canoscan 4400F that works OK for slides and negatives (as well as regular scans) and should cost you less than $100.
Got many scans on here with it.
The resolution is what you want it to be, within the limits of the machine. I scan to get an image of around 3600x2400 pix then process it (remove dust, etc).
JakTrax
Thu Jul 10, 2008 12:22 pm
Quoting Walter2222 (Reply 3):
Canon 8400F
Quoting Oly720man (Reply 4):
Great stuff! I imagine the 8400F is the better? How much is that? Do these scanners have some sort of special cradle to put your neg's in to scan them? I assume they are meant to scan neg's?
I always thought that scanners which can process neg's cost an absolute fortune?
Karl
dvincent
Thu Jul 10, 2008 12:40 pm
If you guys don't mind looking for a used scanner, the Minolta Dimage Scan series is an excellent option. They're tough to find used though because they are just so good... but I can't recommend anything else; from my own personal use it brings exemplary output.
If a brand new unit is a must, the Nikon Coolscan 5000 is also an equally good choice.
From the Mind of Minolta
oly720man
Thu Jul 10, 2008 12:57 pm
Quoting JakTrax (Reply 5):
Yes, in mine there's a special holder that clips into the cover and holds 4 slides or a strip of 6 negatives. Any slides/negs are backlit from a light in the cover.
The ones specifically for negatives usually are, but I think they have a higher resolution than an A4 flatbed scanner.
JakTrax
Thu Jul 10, 2008 1:08 pm
Canon 4400F or Epson Perfection V200, both £69.99 (US$135.00) @ Jessops.com.
Which one would anyone recommend?
Karl
viv
Thu Jul 10, 2008 1:16 pm
Quoting Oly720man (Reply 7):
Yes. The best ones (like the Nikon Coolpix 9000) are expensive but give great results when used properly.
oly720man
Thu Jul 10, 2008 1:39 pm
As an example from my scanner (when they were a bit more amenable at CDG.)
This is more or less a full size KC64 slide scan at 3900x2600 straight from the scanner (but sized at 1024x683 by flickr). Beware dust. You might not be able to see it but you will scan it.
tu-tam_cdg_0886
And this is the nose at 1024x683, so full size as scanned. The jags in various places suggest that the the scanning resolution is a bit high (scanner "pixels" bigger than corresponding detail on the photo)
tu-tam_cdg_0886_big
strikeeagle
Thu Jul 10, 2008 5:44 pm
Hi , The minolta dimage scan elite 5400 is a very good dedicated scanner for both
negs and slides , i dont think however that minolta make these now so i guess
you would have to search for a used one ? A few years back a decent quality
film scanner was about £400 plus , there are cheaper ones available now i
think such as flatbed scanners that will do both print and negs - slides etc .
I would say though that if you have a lot of film negs or slides that you want
to preserve then go for a dedicated film scanner as these produce high quality
images .
Anthony
JakTrax
Thu Jul 10, 2008 5:51 pm
To be honest, if Oly720man can get images accepted here using a Canon 4400F, the reproduction quality can't be bad at all.
Think I'm gonna order the Canon from Amazon, at £59.99 inc. delivery - I looked at the Epson but think I'd rather go with the Canon. Good decision?
Karl
dendrobatid
Fri Jul 11, 2008 7:59 am
Quoting Dvincent (Reply 6):
Absolutely agree
I had a Nikon Coolscan III that failed. I had always considered that to be pretty good and went to buy a Coolscan IV simply because the Minolta one had been discontinued, though it had the best reviews. When I got to the shop they actually had a few Minolta Dimage Scan Elite on offer as a discontinued line and I bought one as it was considerably cheaper than the Nikon
What a move ?
The results are superb with excellent shadow and highlight detail, far far better than the Nikon and I had to rescan a lot that I had done before. The only downside is that it is rather slow particularly when Digital ICE is used (the Elite 2 was faster). Whilst capable of scanning at 5400 DPI I generally scan at 2700 or 1800 for here
I also have a Canonscan 9950F (a flatbed) on which I can scan 120 film negs and transparencies. It gives good results with 35mm too and whilst the resolution is the same as my dedicated 35mm scanner, I do not find the shadow detail as good (and that is very important for good scans)
Mick Bajcar
romeobravo52
Fri Jul 11, 2008 5:18 pm
I use the CanoScan 8600F and SilverFast software, I'm very satisfied with that.
A small warning: scanning negatives is very addictive!
Roel Bekkering
SNATH
Tue Jul 15, 2008 6:05 pm
(apologies for the late reply here!)
Thanks all for the very useful information. Does anyone know what the differences between the Canon 9950F, 8600F, and 8800F are? Thanks.
Tony
JakTrax
Wed Jul 16, 2008 4:53 am
Hey Tony,
Took the plunge yesterday and bought a CanoScan 4400F (as recommended above). My initial budget was double what this cost (£70 or US$135), however the recommendations regarding its capability convinced me that I really didn't need to spend the extra (I think!).
I haven't given it a blast yet but I'll let you know ASAP how it does and I'll try and post some scans.
Karl
oly720man
Wed Jul 16, 2008 10:16 am
Quoting JakTrax (Reply 16):
I hope you like it. I've had mine for over 18 months now and it's worked fine, when the kids give me enough time to use it.
Quoting SNATH (Reply 15):
The 9950F seems to do every type of film
http://www.photo-i.co.uk/Reviews/int...ve/Scanners/Canon_9950F/page_1.htm
Comparison of 8800 and 8600, along with software comparison here
http://www.stockholmviews.com/canon_8800f_review/8800fpage1.html
8600 vs 9950 here
http://www.stockholmviews.com/canon_8600f_review/8600fpage1.html
JakTrax
Wed Jul 16, 2008 1:27 pm
Oly720man, have you any accepted images here with the 4400F using 35mm standard film (i.e. Fuki Superia 200, which is mainly what I used to use)?
Karl
oly720man
Wed Jul 16, 2008 1:37 pm
Quoting JakTrax (Reply 18):
These are scanned from colour negatives (I haven't got round to doing that many yet)
Photo © Andy Kennaugh
These from colour prints
Photo © Andy kennaugh
Click on the name and I generally say on the photo remarks whether they're slide, print or negative if they're not the occasional digital camera shot.
JakTrax
Wed Jul 16, 2008 1:48 pm
Wow! Those results look really good! I'm just installing the bugger now so hopefully for the benefit of the OP I can post some of my own scans shortly. Oly720man, many thanks for your help in making me make my choice.
Karl
oly720man
Wed Jul 16, 2008 2:03 pm
Quoting JakTrax (Reply 20):
Glad to help. I look forward to seeing some scans.
Andy
JakTrax
Wed Jul 16, 2008 2:34 pm
Well, I think I'm doing something wrong 'cause my first scan is terrible...
Big version: Width: 3504 Height: 2336 File size: 2676kb
Taken from Fuji Superia 200. Any ideas? Bear in mind I've only just plugged the thing in and this is my very first scan.
Karl
JakTrax
Wed Jul 16, 2008 3:02 pm
OK, silly post above - should have read the on-screen manual instead of just the basic scanning guide! I've gone into advanced negative scanning so hopefully the next result will be much, much better...  crossfingers
Karl
dendrobatid
Wed Jul 16, 2008 3:24 pm
Karl
If you have used a lot of higher ISO film like 200 you are probably going to need a noise reduction programme.
Neat Image is dreadful if abused but very good if used at low levels and the free version at www.neatimage.com will suffice.
When all else fails, read the instructions.
Mick Bajcar
JakTrax
Wed Jul 16, 2008 3:44 pm
OK, thanks Mick, I'm gonna have a good read of the manual tonight to see if I can get my head round it all.
Do you think though that good scans (using neatimage too) are possible from Superia 200? Apart from the dust issues and the grain with the SV MD-90 is there anything else there stopping it from being a good scan. In all honesty it doesn't look too sharp to me.
Karl
oly720man
Wed Jul 16, 2008 4:13 pm
Just had a quick go at it and got this...
hz-apf_filtered
Olympus69
Wed Jul 16, 2008 8:25 pm
Quoting Oly720man (Reply 19):
These from prints)
Given similar quality scanners, which method should give the best results - scanning from negatives or prints?
I am using digital now and have scanned pretty well all the colour prints I need. However I have a lot of old B/W pics I want to scan, as well as a lot of old colour slides. I am getting a combined slide/negative scanner but am wondering whether to use it or my print scanner for the old B/W stuff.,
I guess I can answer my own question by trying it both ways,
dvincent
Wed Jul 16, 2008 9:35 pm
Quoting Olympus69 (Reply 27):
Negs will win every time.
JakTrax
Thu Jul 17, 2008 11:30 am
OK folks, here's my first decent scan (I think!). Comments good and bad welcome.
Big version: Width: 3504 Height: 2336 File size: 859kb
Is it alright quality-wise? Anything more I can do? Is it rare enough to have a crack at uploading or am I far away from that point with my scanning expertise (or lack of) at the moment?
Karl
JakTrax
Thu Jul 17, 2008 12:12 pm
Think I'm kinda getting the hang of this - would this be worthy of uploading to the database?
Big version: Width: 1024 Height: 683 File size: 197kb
Karl
PRM
Thu Jul 17, 2008 1:27 pm
Both of those look good enough to make it, (the Let too especially if re-sized to 1024x pixels and post-processed so the defects will be less evident). I've had scans that look a lot worse than this straight after the scan and prior to processing which have become acceptable with some work in Photoshop.
Cheers, Paul
113312
Thu Jul 17, 2008 2:14 pm
I usually scan as a .tiff. Then, clean any defects such as dust, scratches or other spots using Paintshop or Photoshop. Of course, any color or contrast should be fixed. Then I resize and finally save as a .jpeg. The final product is what gets uploaded.
walter2222
Thu Jul 17, 2008 3:30 pm
Quoting 113312 (Reply 32):
 checkmark
Most old slides tend to have color casts, and if not corrected, the shot will be rejected. I had a lot of problems seeing this, but with a lot of help from Mick Bajcar (and examples, and editing help) my scan-results have improved (I am still not perfect but the rejections and the explanation on how to improve have helped me a lot!).
It is also good practise to write in the note to screeners that is a scan. I always include the year of the original (pre-1990's and rare shots get a not-so-tough screening  Smile...).
PS: Be aware, scanning and browsing through old slides/pictures is addictive...
Walter
dendrobatid
Thu Jul 17, 2008 3:33 pm
Karl
Neither are there yet. It is not as easy as it looks and it has taken me a long time to get things right. A lot of my accepted early scans are rubbish and I would suggest spending time getting things right before you start to upload rather than wasting time as I have to by re-uploading.
You will find that the commonest colour cast on these scans is magenta, a reddy-blue and the older the image the stronger this seems to get, presumably due to a dye fading. This is very visible on the LET and it is probably exaggerated by the saturation being too high. If you use Photoshop CS2, press Ctrl+B and add a little green until the pinky cast to the grey sky disappears.
Using the curve Ctrl+M can help a lot with the old scans and this tutorial is superb
http://www.thegoldenmean.com/technique/curves1.html
Someone has already warned that it can become addictive
Mick Bajcar
JakTrax
Thu Jul 17, 2008 3:44 pm
Quoting Dendrobatid (Reply 34):
Er, yeah, haven't stopped since 7am.....
Mick, thanks for the tips, however in all honesty I've only had a two-minute play in PSE5.0 to achieve those results. Colour casts I can probably correct pretty easily, I was more after opinions on sharpness and noise - how are these issues with my scans? Are they sharp enough (or over-sharpened) and have I used Neatimage to maximum effect? If I corrected the casts would they make it here?
Thanks for the feedback, very valuable indeed!
Karl
dendrobatid
Thu Jul 17, 2008 3:49 pm
Karl
Use my profile to contact me please
Mick
JakTrax
Thu Jul 17, 2008 4:10 pm
I would normally put this in the pre-screen thread but I think we'd lose track of where we're at if I did that. Here's a re-edit of the Caribair LET410 - it looks much better to me but I really don't know 100% so if an expert (such as Mick) could give an opinion that'd be great.
Big version: Width: 1024 Height: 683 File size: 193kb
Would this one make it here?
Karl
Olympus69
Fri Jul 18, 2008 4:02 am
Quoting Dvincent (Reply 28):
Thanks. I was hoping that would be the case since my B/W prints are rather small.
John.
walter2222
Sat Jul 19, 2008 12:49 pm
This is a very good read for people that want to know somewhat more about scanning:
http://www.scantips.com/ (by Wayne Fulton)
PS: Most of the info can be found on the webpages, but I have also ordered the printed version (it was only about 24 US dollars - for 240 pages packed with valuable info - when I ordered it) to support the writer for bringing all this info together in one document.
Walter
