kkonstantin
Rejected. Your Ideas.
Mon Jul 21, 2008 7:50 am
Posted this photo: http://www.airliners.net/addphotos/big/ready/APPEAL_20080720_VPBYJ.jpg
Reject reason - colour centered.
Any toughts?
DM
RE: Rejected. Your Ideas.
Mon Jul 21, 2008 8:28 am
Quoting Kkonstantin (Thread starter):
Any toughts?
It looks like the image has a blue cast to it. Centered rejection is correct since the aircraft is too low in the frame.
Could you post the original image resized?
[Edited 2008-07-21 01:30:15]
kkonstantin
Mon Jul 21, 2008 9:07 am
Unfortunately my status doesn't allow to attach images. The posted photo is actually original - converted from RAW in DPP Canon utility without any white balance correction (just crop and noise reduction later in PS). On my calibrated monitor it looked fine and I decided not to make any corrections.
DM
Mon Jul 21, 2008 9:58 am
If the original image is too low in the frame i wouldn't try to edit the shot since the size of the image will be out of A.nets requirement.
DM
dendrobatid
Mon Jul 21, 2008 11:10 am
Quoting DM (Reply 3):
Not necessarily.....
Try cropping closely to the wingtips and take some off of the top and you might just get away with it. At 1024 wide the minimum size is 683 high.
It is too blue
Mick Bajcar
ZakHH
Mon Jul 21, 2008 4:40 pm
Quoting Dendrobatid (Reply 4):
It is too blue
Why would you say so? I don't have PS at hand, but the first visual impression is good (I'm sitting at a freshly calibrated monitor as well). Whites look white, can't see any cast.
Anyway, as I said - visual impression only.
Tired of a.net? Join a friendly aviation community!
kkonstantin
Mon Jul 21, 2008 6:05 pm
All the same. I have just recalibrated monitor. Checked connection and just as for the experiment changed LCD to CRT monitor, calibrated and saw no difference. Where is the BUG ????
