Did
Would Accept This Pic On A.net...?
Wed Jul 23, 2008 7:16 pm
Hi every body,
Is any (good) reason why this picture was rejected for airliners.net..? i'dont understand what's really wrong (sometimes i'do..; ;<) ). Tanks for help. Did
http://www.flickr.com/photos/9302672@N08/2695874179/
TransIsland
RE: Would Accept This Pic On A.net...?
Wed Jul 23, 2008 7:37 pm
Well, it's kinda hard to tell from the small flickr image... how about posting the actual rejected file that you uploaded to a.net.
At first glance though, the highlights look blown out.
I'm an aviation expert. I have Sky Juice for breakfast.
NIKV69
Thu Jul 24, 2008 12:20 pm
Nice subject! Would have to see the original though. Can you post it?
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
Granite
Thu Jul 24, 2008 12:25 pm
Hello
Yes, need to tell us why it was rejected also.
Small image looks good but you need to show/tell us more.
Gary
Scotland1979
Crew
Thu Jul 24, 2008 2:23 pm
Quoting TransIsland (Reply 1):
Need larger photo so we can tell from there
Jesus said "I am the Way and the Truth and the Life. No one comes to the Father except through Me" - John 14:6
Did
Thu Jul 24, 2008 8:01 pm
Hi,
Here is the original pictures that was rejected (any size problem...?)
i'dont see...
thanks for your comments :
http://www.airliners.net/procphotos/...main?filename=20080723_bucker2.jpg
NIKV69
Thu Jul 24, 2008 8:24 pm
Yes 1024 by 780 is too big, try using 1024 by 683 would look better.
Stealthz
Thu Jul 24, 2008 9:11 pm
Quoting NIKV69 (Reply 6):
Well, no it isn't 4:3 aspect ratio is perfectly acceptable here, Agree it might look better at a 3:2 crop.(a personal & subjective opinion)
Might be an info rejection as location is clearly NOT "In Flight"... the dreaded "Level" reject might be a possibility as well
Nice Pic though,
Chris
bubbles
Crew
Thu Jul 24, 2008 9:18 pm
Quoting StealthZ (Reply 7):
And other info also has problems.
Yes, clockwise rotation is needed.
_Hongyin_
Jonny
Thu Jul 24, 2008 10:28 pm
Well, the photo isn't level for one thing. I happen to think that there is too much sharpening around the tail area. A somewhat clockwise rotation is needed, just as Bubbles has mentioned.
I also agree with size ratios.
It might have some info problems since it is not very what I call "today's edge". What I mean is it is an old aircraft meaning there might be some info problems.
Hope this helps!
Jonny
qswags
Fri Jul 25, 2008 2:04 am
Looking at the edges that outline the plane it might be rejected for 'soft'. I have had some pictures that were rejected for that reason and they looked as sharp as the edges you have here. I would have to agree that the tail does look a little bit oversharpened since you can see jaggies on the x. If you have Photoshop some time should be invested in careful sharpening. Great picture otherwise.
Quentin
"I think your problem is low self-esteem, that's a common problem with losers."
