jgpitre
Is This One Worth A Fix Up?
Sun Jul 27, 2008 4:39 am
This shot got rejected. I understand the oversharpening and will get help with the contrast. I am wondering about the cropping:
I got a personal note that it is too low in the frame. I can not go any lower. And it is cropped 3:2 ratio, so I can not take more off the top. Does this mean the shot is a write off for A,net?
http://www.airliners.net/addphotos/r...703_June_29_2008_Photo_2c_copy.jpg
daPap
RE: Is This One Worth A Fix Up?
Sun Jul 27, 2008 8:59 am
Send the original to office@papchristopher.at or post it here and I will do my best to correct the center rejection.
Christopher
viv
Sun Jul 27, 2008 1:09 pm
There IS scope for cropping more off the top, because of the empty space behind the tail.
Of course, you would have to use the original uncropped image as a basis.
[Edited 2008-07-27 06:10:47]
jgpitre
Sun Jul 27, 2008 2:09 pm
Quoting Viv (Reply 2):
I guess part of what I am asking is do the afterburner rings I deliberatley left in add enough to the picture to keep in?
I have left as much as possible on the front and bottom in my cropping. There is absolutely no way to raise the plane with losing afterburner or nose because of a slight rotation issue. This is an uncropped/unedited version
http://www.facebook.com/photo.php?pid=3649057&l=75171&id=595075050
viv
Sun Jul 27, 2008 2:15 pm
Yes, I see your problem.
One to frame at home, I'm afraid.
TransIsland
Sun Jul 27, 2008 2:24 pm
I think it would still be too low in the frame. My guess is there's little to be done that would be acceptable here...
Big version: Width: 500 Height: 333 File size: 42kb
I had to stretch that grass quite a bit.
I'm an aviation expert. I have Sky Juice for breakfast.
jgpitre
Sun Jul 27, 2008 3:24 pm
That is what I was afraid of..I am proud of the shot because it was a touch and go--the runway is too short for him to land.
So is the lesson I need to take away to not zoom in as close so I have more crop flexibility?
viv
Sun Jul 27, 2008 4:25 pm
Quoting Jgpitre (Reply 6):
Or centre the aircraft in the frame when taking the shot.
jgpitre
Sun Jul 27, 2008 6:02 pm
Quoting Viv (Reply 7):
I checked..he was on the ground 4 seconds! I took 21 shots. He was on afterburner from touch down. I estimate he was going at least 300mph based on the size of the runway. I don't think I did too bad having him centered..Considering that was a 200 mm focal length.
Edited to add a link to all 21 shots.
http://www.facebook.com/album.php?aid=140488&l=e2e3b&id=595075050
[Edited 2008-07-27 11:35:52]
