McG1967
Level And Contrast
Mon Aug 18, 2008 2:01 pm
I had the following 2 shots rejected for level,
http://www.airliners.net/addphotos/r...ig/20080817_IMG_2045-Edit-Edit.jpg
http://www.airliners.net/addphotos/r...ons/big/20080817_IMG_2101-Edit.jpg
I am thinking between 0.3 and 0.8 CW to get them level. Would I be going along the right lines with this sort of value.
Following shot was rejected for contrast,
http://www.airliners.net/addphotos/r...s/big/20080817_IMG_2037-Edit-2.jpg
I think I need a touch less contrast on the image. Yes / No?
JakTrax
RE: Level And Contrast
Mon Aug 18, 2008 2:28 pm
You are correct. The Uzbek is nearly level, and the right-hand verticals are actually level but if you look at the left-hand verticals they lean to the left. Best to always use a vertical in the centre of the frame - in your case there isn't really a great one visible so go for a balance whereby the left-hand-most vertical leans in that direction by the same amount as the right-hand-most vertical leans in the opposite direction (if you know what I mean).
Karl
NIKV69
Mon Aug 18, 2008 3:45 pm
Quoting McG1967 (Thread starter):
Sounds good also I would give them a little kick of sharpness too, both need a little especially on the titles IMO.
SPOILER ALERT! Hillary Won!
Users browsing this forum: MattSax and 5 guests
