sovietjet
Settings For Night Photography?
Thu Aug 21, 2008 12:49 am
Looking at some of these pictures I was wondering...how is it done? Usually I only shoot in the afternoon/dusk because of work/school and I tend to leave during the "blue hour" since my shots come out blurry or out of focus after that. I have tried fiddling with the settings but with little success. I'm not talking about dusk/dawn here, I'm talking about full darkness. Any tips?
Photo © Ivan P. Nesbit - Mexico Air Spotters
Photo © Kevin Scott
Photo © Gerhard Plomitzer
Photo © Mark McEwan
Now, I know you can jack the ISO up to get rid of blurriness but doesn't that cause a lot of grain? For example this picture was done with ISO1600!! and yet it doesn't have significant grain, how?
Photo © Karl Drage
Also in all these situations, should manual focus be used? Anyone care to share some hints/tips on these types of shots? If it helps, I am using a Canon 40D with a 100-400L lens.
wilco737
RE: Settings For Night Photography?
Thu Aug 21, 2008 8:09 am
Quoting Sovietjet (Thread starter):
Very interesting question. I have the same question. I hope someone can provide an answer here.
All my results were amazingly blurry, way too dark, grainy, noisy etc etc... No chance to get a proper sharp picture...
Great camera and great lense, I use the same  bigthumbsup
WILCO737 (MD11F)
 airplane
DABZF
Thu Aug 21, 2008 10:33 am
Now, someone correct me if I'm wrong here but for the example shots #1 and #3 and #4 I would take spot metering from the #1-flare #3-afterburn #4-moon. Everything else except the light sources in these pictures are dark, if not black (I'm on a bad/dark monitor currently). You should be able to get rather fast shutter speed by taking the reading from these points.
For #2 and #5 you need a VERY steady hand to be able to get panning shots on shutter speeds as low as 1/10 or 1/20 - I can't even dream of that with my shaky hands...  Sad
I like driving backwards in the fog cause it doesn't remind me of anything - Chris Cornell
wilco737
Thu Aug 21, 2008 10:44 am
Quoting DABZF (Reply 2):
Yeah, I wasn't very successful with such shots myself. Most are blurry  Sad
It looke like the shutter speed is pretty short, as seen in #2. The background lights are just slightly blurred because of the motion. But the aircraft is pretty sharp.
Pic #4 looks a little grainy to me (but this might be this cheap stupid laptop  banghead  But I guess even here the shutter speed is pretty short and the ISO is at maybr 1600 or so?
WILCO737 (MD11F)
 airplane
timdegroot
Thu Aug 21, 2008 10:47 am
High iso and the prominence of bright lights in the pictures make them doable but challenging nonetheless
Tim
Alderman Exit
wilco737
Thu Aug 21, 2008 11:02 am
Quoting TimdeGroot (Reply 4):
doable
Yeah, I can see that Big grin
challenging
OH YEAH indeed, very challenging. Congrats to the good work of the photographers.  praise
WILCO737 (MD11F)
 airplane
sovietjet
Thu Aug 21, 2008 5:29 pm
What is spot metering?
DABZF
Thu Aug 21, 2008 6:10 pm
Quoting Sovietjet (Reply 6):
Check the manual of your camera and/or google "spot metering"  Wink
RBayflyer
Thu Aug 21, 2008 10:13 pm
I've got a Canon EOS 350D
I battle to take propper night shots...it comes out blurry, whats the best settings, please explain in normal common steps and language please.
Sky's the limit!
timdegroot
Thu Aug 21, 2008 10:15 pm
Quoting RBayflyer (Reply 8):
First step is to ask why they are blurry. Are you shooting moving aircraft at night or static. If the latter are you using a tripod?
Tim
Alderman Exit
soon7x7
Fri Aug 22, 2008 7:47 pm
For celestial type night shots (plane/moon), I've used iso 800, n/reduction,1/250sec w/ 600 mm lens and 1.4 adapter...on tripod w/ cable release., Static exteriors,2-3 minute exposures on tripod, ISO 100. Moving objects at night, ...ISO 200-800, fast lens...panning on tripod if able and much luck...
Big version: Width: 1024 Height: 683 File size: 465kb
40 million will get you one of these
Big version: Width: 1024 Height: 683 File size: 626kb
challenger series 600, 601, 604's before they became crj's
Samuel32
Fri Aug 22, 2008 11:26 pm
I've heard with certain tripod heads (wimberly?) you can get sharp stuff in the worst situations?
Sam,
Scotland1979
Sun Aug 24, 2008 3:04 am
Quoting WILCO737 (Reply 3):
Me too and I am still working on it. And too bad YXU doesn't have that kind of lights at night. I will try YYZ at night however I need to know which set first before trying YYZ
Quoting DABZF (Reply 7):
"spot metering"
I will check that... thanks for mention that
Jesus said "I am the Way and the Truth and the Life. No one comes to the Father except through Me" - John 14:6
