eadster
Contrast And Reflection
Wed Sep 03, 2008 9:20 am
hey Guys,
I had a note on this rejection pointing out the reflection on the aircraft.
http://www.airliners.net/addphotos/rejections/big/20080902_vh-ppj.jpg
As I didn't think it was an issue, can I assume that the shot won't make it?
Thanks in advance,
scbriml
RE: Contrast And Reflection
Wed Sep 03, 2008 9:52 am
Quoting Eadster (Thread starter):
In and of itself, I don't think a highlight is a big problem, indeed, it can even add to a shot. Were there any other rejection reasons?
viv
Wed Sep 03, 2008 2:09 pm
Rejection solely on the basis of the reflection seems a bit harsh.
ac888yow
Wed Sep 03, 2008 2:42 pm
Looks like a possible clipping issue to me. I'd be willing to bet that the reflection is less severe on the original and that it has been amplified during levels adjustment or similar.
If so, tone back the levels adjustment to reduce the severity. You can hold down ALT while adjusting the levels sliders to view the clipping areas.
If not and the original looks like that, you may be out of luck.
dvincent
Wed Sep 03, 2008 2:45 pm
Highlight recovery on RAW always helps, but something like that will always be "too bright." It's a case where you try to minimize the reflection.
From the Mind of Minolta
JakTrax
Wed Sep 03, 2008 3:19 pm
Quoting Dvincent (Reply 4):
This type of reflection, which I refer to as 'sunflash' or 'sunstreak' and absolutely detest, will always be too bright no matter what, so I don't see why this was rejected. There is no rejection reason stating anything about 'sunflash'. I personally hate any amount anywhere but I've seen plenty of shots here featuring this personal nuisance which are no worse and have highlights no less bright.
Karl
bubbles
Crew
Wed Sep 03, 2008 3:55 pm
Hi Martin
I rejected this photo. I think the reflection on fuselage, especially on rear fuselage, is too harsh. The highlight area are too wide and too much detail lost there.
_Hongyin_
eadster
Thu Sep 04, 2008 1:01 am
Quoting Bubbles (Reply 6):
Thanks for owning up. I personally think its a harsh rejection myself but anyway, clearly its not going to make it. I uploaded the shot only because its a rare case to see this type flying in Australia as they are constantly riddled with unserviceabilities. Anyway, another for the scrap heap.
Thanks all for replying.
