ptrjong
Hand Luggage Camera Backpack
Fri Sep 05, 2008 2:52 pm
Hi all,
I'd like to fit a DSLR, a kit lens, a small telezoom(Nikkor 70-300VR) and a big telezoom(Bigma), as well as a medium-sized laptop in a camera backpack, and take it into an airliner as hand luggage. Will this work, and can you recommend any bag?
Peter Smile
timdegroot
RE: Hand Luggage Camera Backpack
Fri Sep 05, 2008 2:57 pm
Computrekker
Tim
Alderman Exit
walter2222
Fri Sep 05, 2008 3:11 pm
Quoting TimdeGroot (Reply 1):
Computrekker
 checkmark
http://products.lowepro.com/product/CompuTrekker-AW,1924,16.htm
But fully loaded, you should not put it into the overhead luggage compartments... When I last travelled with it, they asked me to take some heavy stuff out (telezoom & laptop)...
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
dvincent
Fri Sep 05, 2008 3:19 pm
I use a computrekker that doesn't have the "rolling" attachment and it's an excellent bag with no problems going in the overhead. But maybe the rolling mechanism really adds some weight...
From the Mind of Minolta
timdegroot
Fri Sep 05, 2008 3:24 pm
I actually have a computrekker plus which is bigger but with your kit you probably dont need it
Tim
Alderman Exit
ptrjong
Fri Sep 05, 2008 3:42 pm
Thanks Tim, Walter and Dan! Sounds like the right solution.
Peter Smile
walter2222
Fri Sep 05, 2008 3:45 pm
Quoting TimdeGroot (Reply 4):
 checkmark
...but one can always find stuff to fill the empty spaces  Smile (and make sure it is future-proof, you might want to buy more equipment).
Peter, I think you best go to a shop with all your gear and try one out! That is the best way, before buying!
Walter
INNflight
Fri Sep 05, 2008 5:30 pm
Computrekker
Same here, even though I prefer a normal backpack for travelling and just throw my cam in  Embarrassment
A LowePro backpack always SHOUTS OUT "steal me"... imho!
Computrekker is nice. You can fill the empty space with chargers, a flash, maybe some travel docs, whatever.... highly recommend it!
Jet Visuals
diezel
Fri Sep 05, 2008 6:58 pm
I use the Lowepro Minitrekker AW. It fits my D300, 200-400, 12-24, 18-200, 80-200 and an Asus eee mini laptop. It's very, very small, I have owned it for more than 4 years now and I had never any trouble checking it in as hand luggage.
However, there are two things that I have against it: I cannot mount a lens on my camera when the 200-400 is inside. It's not really a quick access bag. And the all weather cover has a velcro lock which is on the underside of the bag and attracts a lot of dirt, grass and other stuff.
Otherwise, highly recommended.
http://products.lowepro.com/product/Mini-Trekker-AW,1965,14.htm
Roel.
Never be afraid of what you like. (Miles Davis)
whappeh
Fri Sep 05, 2008 7:20 pm
I've noticed a lot of you guys saying you put your camera bags in the overhead? Really? I've never wanted to take the chance of someone coming by and jamming a ton of stuff ontop of it or moving it with out my knowledge or anything of the sort. Is it really that safe to put your camera bags in the overhead?
-Travel now, journey infinitely.
timdegroot
Fri Sep 05, 2008 7:35 pm
Quoting Whappeh (Reply 9):
large backs wont fit under the seat, and forget about checking them
Tim
Alderman Exit
TransIsland
Fri Sep 05, 2008 7:46 pm
I have this one, and can recommend it:
http://www.amazon.com/Urban-Gear-U10...UTF8&s=photo&qid=1220643892&sr=1-3
It fits into most overhead bins (at least one the larger planes), on the ATR, it still fits under the seat though I usually valet check it.
My main reason for loving it: I had a motorbike accident last November (I hit a car that had ignored a stop sign at about 60 km/h), and had all my gear in the backpack. As I went flying, the straps ripped, and the backpack landed about 15 metres away. While the backpack was no longer usable, all my gear was fine!
I'm an aviation expert. I have Sky Juice for breakfast.
ake0404ar
Fri Sep 05, 2008 7:47 pm
Peter,
I even traveled with a Tamrac Expedition 8 and a Lowepro Stealth Reporter AW 650 as carry on. No questions asked. (then again it was C-Class, mabye that did the trick)
Ever looked at http://www.thinktankphoto.com/ttp_product_ArprtAStrm.php
and it does not.....
Quoting INNflight (Reply 7):
Vasco
dvincent
Fri Sep 05, 2008 7:50 pm
Quoting TimdeGroot (Reply 10):
Nail, meet head.
The computrekker is a robust bag that can take a beating, but it's not a pelican. I'm comfortable with it in an overhead.
For reference, I can have my a700 mounted to my Bigma with storage for 4 more lenses (70-210, 100-200, 17-50, 50mm), cleaning supplies, scanner, and there's still room for a flashgun. This doesn't include the rest of the space, which holds laptop, monopod, etc... the CT is really one of the best bets in bags.
photopilot
Fri Sep 05, 2008 8:03 pm
I've got the CompuTrekker Plus AW and I simply can't say enough good things about this pack. Even fully loaded and overweight, it's still very comfortable to carry as it has super straps. I've put mine under the seat or in the overhead and not had any problems.
ptrjong
Fri Sep 05, 2008 11:12 pm
Quoting Walter2222 (Reply 6):
Yes, I will sure do that, but it's great to know what types others recommend. This is still a great forum!
Once I get it on board, I'm sure I'll find a place for the bag somewhere, and I'm not worried about putting it in the overhead bins. I'm more worried about getting it on board in the first place. Are you guys saying a bag of Computrekker size is never a problem to get on the plane - it actually meets the size requirements for hand luggage?
This may sound a bit stupid, but I've always preferred to travel with just a light 70-300 so far, and I've yet to buy the laptop Wink
The immediate reason for this is a trip to Malta around the Sep 27-28 airshow, by the way. If anyone else is going there, please let me know!
Peter Smile
dvincent
Sat Sep 06, 2008 1:48 am
Quoting Ptrjong (Reply 15):
Lowepro guarantees it. If the bag lit has the little airplane logo, you're good to go.
eadster
Sat Sep 06, 2008 6:13 am
Only trouble I've found with camera backpacks, is travelling on smaller aircraft. I do a bit regional travel, and have found that the camera bag has trouble fitting in Dash 8 overhead lockers. So the bag stays at my feet when on these.
diezel
Sat Sep 06, 2008 8:01 am
Peter, there is sometimes a weight limit on hand luggage. You might want to think about that when packing your bag.
For KLM this is 10kg, for Air Malta this is only 5kg. The usually never weigh it (at least not mine  Smile ) but you never know.
Have fun in Malta!
Roel.
JRadier
Sat Sep 06, 2008 8:11 am
Quoting Diezel (Reply 18):
If they do weigh it, start hanging camera's around your neck, lenses in your pants (the pockets, obviously) etc. Once in the jetway repack the thing.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
ptrjong
Sat Sep 06, 2008 9:21 am
Thanks again for all the good advice!
Peter
andz
Sat Sep 06, 2008 9:29 am
I use a Lowepro Compuday backpack as the primary use is for the laptop but it fits my 350D with 28-200 plus battery charger and cables in the bottom compartment quite comfortably.
moving it
I had that recently, a guy took my bag out of the overhead and replaced it with his pull along, then headed to the back with my bag. I told him to put it back and the ensuing argument required the intervention of the cabin crew to resolve. My backpack went back above my head and the pull along went into the hold  Smile
cpd
Sat Sep 06, 2008 10:02 am
Quoting Ptrjong (Thread starter):
I did this last year with a BMW Lifestyle collection "7 series" roll-aboard type bag. It worked fine - but it's not easy packing and unpacking this kind of arrangement. But it was much more rugged that the typical camera backpacks.
But this was on international flights mostly, (B747, B767) and a couple of domestic flights (A320, B757). Never went on any small planes like regional turboprops or jets. I wouldn't take a camera backpack, it just screams "steal me", just like those laptop bags with "DELL" or "VAIO" or other names on them.
DYflyer
Sat Sep 06, 2008 6:33 pm
I am another user of the Computrekker. Wouldn't change it for anything else (perhaps except the "plus"-version  Smile ). Never had any problems getting it onboard. Even on regional jets or dash 8s.
Life is like a book. If you don't travel, you only read one page.
Users browsing this forum: DarkSnowyNight, eggohoek and 1 guest
