744flyer
Suggestions For Shooting Cabin/Flight Deck Shots
Wed Oct 01, 2008 7:23 pm
Hey guys,
Tomorrow, a friend of mine is giving me a tour of a couple FedEx jets, and I was hoping to get some good pictures of the inside cabin, cargo compartment, and the flight deck. I was wondering if anybody had any helpful tips for camera settings, use of flash, hotshoe, tripod or anyother tips??
Thanks four your help.
Luke R.
timdegroot
RE: Suggestions For Shooting Cabin/Flight Deck Shots
Wed Oct 01, 2008 7:26 pm
Hi luke
Dont mind helping but if you search this forum there must be dozens af very good posts with tips and tricks on the subject
Tim
Alderman Exit
744flyer
Thu Oct 02, 2008 12:28 am
Thanks Tim,
I'll look into those posts.
Sorry about this.
-luke
jorge1812
Fri Oct 03, 2008 9:46 am
Why not start a Masterclass thread about that subject, would be interesting.
georg
gliderpilot08
Fri Oct 03, 2008 1:57 pm
Quoting Jorge1812 (Reply 3):
??? What is a master class thread - for Aviation Photography???
Gimli Advisory. Sierra, Oscar, Romeo on right downwind for Rwy 15
soon7x7
Fri Oct 03, 2008 3:05 pm
A great way to capture interiors is at night....cameras don't like dealing with two primary light sources (daylight/artificial). You must choose your primary light source,...artificial or ambient daylight. Interior shots come out better at night when using onboard lighting as primary source.
Best at night if crew can give you power for onboard lights as primary light source...use time exp/ w tripod, low iso settings and shutter release cable.Daytime,... avoid flash shots inside unless you combine with ambient light/ flash as fill source...If cargo bay has few windows ask for onboard lighting and time expose...no flash...usually those interiors are well lit and outside light is minimal through door and exit windows....close cockpit door...
I just set color temp on auto and/or use gray card if you have one.
On time exposures, set long exp noise reduction ON.
Reduce contrast setting if you can.
Cockpit shots day...use exp lock on outside exp, then bounce flash...
night cockpit..pretty much same as above or time exp..
Any way...at work...probably confused you...ask away if any ?'s
