JakTrax
Removal Of Captions On My Latest Uploads
Mon Oct 13, 2008 2:42 pm
Hi all,
Can someone in the know please explain something to me? A couple of my latest uploads have been accepted but the captions with which I supplied the images have been removed; and I've no idea why.
The photo's in question (and underneath I have included the removed captions for you to scrutinise) are (sorry, I can't get the proper image links to work)...
http://www.airliners.net/photo/CSA---Czech/Boeing-737-55S/1409252/M/
http://www.airliners.net/photo/Centr.../Cessna-525-CitationJet/1409251/M/
CSA caption - "Rolling past the AVP (which remains). Notice the first officer's arm waving out of the open cockpit window (this sentence removed)"
Biz-jet caption - " New registration to A.net"
Now were these captions considered inappropriate or politically incorrect or something? I'm baffled by this one I'm afraid - there seems no need for anyone to have messed around with these.
Let me just point out that I'm not particularly bothered by this - I'm just curious as to why this has happened and for what reasons (if any); if only to assist me with future uploads.
Thanks.
Karl
[Edited 2008-10-13 07:44:52]
Fly747
RE: Removal Of Captions On My Latest Uploads
Mon Oct 13, 2008 2:56 pm
Quoting JakTrax (Thread starter):
A.net takes this as a hit seeking comment...
Not sure about the second one Karl.
Ivan
9VSPO
This is pointing out the obvious. People who view the photo can already see this. Adding comments like that IMO is a blatant attempt at getting more hits.
If it was up to me, I'd ban people from making any comments whatsoever unless it was vital.  Wink
[Edited 2008-10-13 08:00:09]
jorge1812
Mon Oct 13, 2008 3:09 pm
Unfortunately also the "first one on Anet" remarks are not allowed...also are words which "make" the viewer opening the big version of the pic (waving pilot).
georg
whappeh
Is there really a problem with a "hit seeking" comment? There are several hundred, if not thousand, photos in the database with irrelevant comments designed to seek attention.
-Travel now, journey infinitely.
JakTrax
Mon Oct 13, 2008 4:05 pm
Well let me say neither caption was intended to get more hits - and even if they were, where's the 'cheating' in enticing people to open your image? It's not like you're forcing them or abusing the system in order to up views.
Because I shot the whole aircraft and didn't particularly highlight the waving co-pilot I thought I'd point it out as to me it doesn't seem that obvious, especially from a thumbnail. I think a waving crew member makes for a different and interesting shot and that's why I included the caption. Take it as you will. I'm sure if someone shot an airliner with an engine on fire they'd point it out, as from a thumbnail it may not be obvious. In my case I assure you that I never had number of views in mind. Most of us have seen a waving pilot before and in my opinion it's not something that would make me open an image.
As for the biz-jet, I've seen many images here with such comments. "New to the DB", "First photo on A.net", etc. etc.
I really don't care much about views. If you look at my images in the database it's obvious to see that, normally, I only put up images I think others will find interesting. I don't get back from an airport visit and upload every single shot from the day, because much of it will have been seen before and will get repetitious. I understand that some people like to do this, but it's not for me.
Karl
acontador
Mon Oct 13, 2008 5:28 pm
Hi Karl,
Please note following extract from the Upload FAQ:
We reserve the right to make changes as we see fit.
The thing with the 'waving' comments is that they are deemed to be only hit-seeking and not relevant at all to the picture (you can see them anyway).
The 'first in DB' remark should also not be used, as the registration might be new when you upload but not necessarily when it gets accepted (others might have uploaded before you). Additionally, it is also deemed to be only hit-seeking and not relevant at all to the picture.
And yes, you will find some pics accepted with these comments, the same way you are going to find some soft/dark/dirty/etc...
Just sit back, relax and have a glass of Merlot...enjoy your life!
JakTrax
Mon Oct 13, 2008 6:03 pm
OK Andres, thank you.
I was only seeking an explanation - one I don't necessarily agree with but I've now had that explanation.
I'll obviously try and avoid such captions in future, however it seems too fine a line - what is classed as hit-seeking and what isn't?
To highlight my plight, below are a few captions from recently-accepted shots which, according to Andres' reply above, I feel are not too indifferent from those removed from my images.
"You have to have a steady hand to capture these images - especially with a lens without IS!"
Doesn't this caption suggest that the image is different to a standard shot (the props are blurred) and therefore is more likely to be opened?
"Odd-ball nose-cone and also non-standard grey winglets."
Again, despite being obvious - even in thunmbnail - doesn't this suggest a difference from the norm and therefore is more likely to be opened?
"Looks like the birds in the grass have selected the prime spotting spot....."
Not obvious from thumbnail but again inviting the viewer to look at the birds in the grass staring at the aircraft. Is this not more likely to be viewed because of that statement?
I don't want to open a can of worms here but sometimes the discretion applied is far too broad-ranged. It all seems a bit odd to me but I suppose rules are rules.....
Karl
ghostbase
Tue Oct 14, 2008 1:14 am
So just how far does A.Net go with removing 'hit seeking' comments? For example would this be acceptable today?
Photo © Michael Baldock
Caption: "Look VERY carefully in the former bomb aimers window under the nose!"
Given that the Shackleton at that time was about to replaced by the Sentry the cheeky estate agent's 'For Sale' board in the window was both humourous and relevant, and definitely worth a comment. Personally, these days I could not care less how many hits the photo gets however what I want to do is try to convey to the viewer what I experienced at the time which, in this case, was definitely a wry laugh at the Shack crew's sense of humour  Smile
This photo could have been another example:
This Finnish MiG-21 took off and performed a complete practice air demo routine at Kuopio-Rissala in May 1988. I was literally the sole spectator standing in the observation area and when the MiG landed and taxied past the pilot saw me and snapped a sharp salute, a memory I will cherish to my final day. Had I photographed that salute and highlighted it in my 'photographers comments' would that now be deemed as 'hit seeking'? Feedback above suggests that it would be regarded that way.
Many of the photos that I have posted on A.Net are very personal to me and mark when I have seen a type of plane for the first time, or perhaps are associated with an event or have particular memories attached to them. My photo comments are made to reflect these and are not intended to attract attention to generate hits.
I think that the contributing photographer should have the right to make comments as he/she decides and if A.Net disagrees with those comments then the photo should be rejected (badcomment??) and the photographer should have the right to appeal the photo with a reason for the comment or re-submit with a changed photographer comment. It should not be subject to arbitrary censorship. My attitude is that the comment has an equal footing with the photo and if the comment is 'rejected' then A.Net does not have the right to carry the photo. An unusual attitude I admit but that is me  Wink
Quoting 9VSPO (Reply 1):
I note your 'wink' but if it *was* up to you this would be a seriously boring database!
 ghost
"I chase my dreams but I never seem to arrive"
jetmatt777
Crew
Tue Oct 14, 2008 2:15 am
There's been many times where I load up a pic, and then 3 or 4 days later, stumble across it again and see in the remarks where the photographer makes note of something interesting, that I completely missed before.
I just don't like that attitude, just because something is visible in the photo, does not mean it will be seen. In fact, A.net might be losing ad clicks by encouraging photographers to not note anything which may attract page views. Even if it is not intended by the photographer.
One of my photos, I included in the remark "Interesting Reg Number Colors..." Not to entice hits, but to point out, that having multi-colored reg numbers is in fact rare, and thought it was noteworthy.
Just my  twocents
-Matt
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
