calfo
Canon 70-200mm
Fri Oct 24, 2008 8:39 pm
So. I'm looking at the Canon 70-200mm lens.
Canon EF 70-200mm f/2.8L IS USM - $1849
Canon EF 70-200mm f/2.8L USM - $1319
Canon EF 70-200mm f/4L IS USM - $1199
Which one is the best for the money?
JRadier
RE: Canon 70-200mm
Fri Oct 24, 2008 9:08 pm
Depends, what do you want to shoot with it?
Besides, don't forget the f/4 non IS
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
calfo
RE: Canon 70-200mm
Fri Oct 24, 2008 9:17 pm
Quoting JRadier (Reply 1):
http://www.vistek.ca/store/CameraLen...m-f4l-usm-telephoto-zoom-lens.aspx
Does that really matter?
ANITIX87
RE: Canon 70-200mm
Fri Oct 24, 2008 9:20 pm
Quoting Calfo (Reply 2):
Yes it really does.
If you're going to be shooting aviation on bright sunny days with short shutter speeds, then all you need is the F4 USM.
If you're going to do panning shots on bright sunny days, you only need the F4 IS USM.
And, lastly, if you want to shoot in darker conditions or rainy weather, than the F2.8 IS USM will be the one to buy for the larger aperture in lower light.
TIS
calfo
RE: Canon 70-200mm
Fri Oct 24, 2008 9:27 pm
Well, it would be to shoot everything basically. Bright sunny weather, rainy, dark, night, and everything else you can think of.
I currently have the 70-300mm F4-5.6 USM. I'm looking for something high quality.
JRadier
RE: Canon 70-200mm
Fri Oct 24, 2008 9:37 pm
That's the IS lens, I'm talking about this one
http://www.vistek.ca/store/CameraLen...-f40l-usm-telephoto-zoom-lens.aspx
Quoting ANITIX87 (Reply 3):
Or if you use it for other things where you would like a small DOF.....
calfo
RE: Canon 70-200mm
Fri Oct 24, 2008 9:48 pm
Another question.
The difference between IS and non IS?
Shooting at
1/1000
1/500
1/20
jetmatt777
Crew
RE: Canon 70-200mm
Fri Oct 24, 2008 9:59 pm
Quoting Calfo (Reply 6):
Shooting at
1/1000
1/500
1/20
Depends on a TON of factors, including hand steadyness.
For some people 1/20 shots panning can be done hand-held, but that number is very few.
1/1000, bright enough obviously to not need IS
1/500 bright enough to not even need IS
For 1/200ish and below there are WAAAY to many factors to determine how IS would help.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
JRadier
RE: Canon 70-200mm
Fri Oct 24, 2008 10:07 pm
Calfo,
I do not want to sound condescending, but perhaps you should investigate more before you do such a purchase. Read about what IS does and when it is helpful, and when it isn't. Read about aperture, the differences between a f/4 and f/2.8 lens and most important of all, think what you really want and see how the choices above fit that. If you have us pick a lens for the 'best value' you are bound to be disappointed, and that with a very expensive piece of glass.
just my 2 cents
gmonney
RE: Canon 70-200mm
Sat Oct 25, 2008 12:15 am
I have the 2.8 IS and its amazing, works great on the 5D. I can shoot in any light at ISO 400 with no grain.... I have done a few weddings and about 95+ pics are amazing. If you have the cash, get the best... you will not regret.... I use my camera about 25% aviation and 75% other... so go with what you do best...
Might I add, the 100-400 is the best aviation lens.... so choose the L glass for your needs not your wants,
Grant
Drive it like you stole it!
Daleaholic
RE: Canon 70-200mm
Mon Oct 27, 2008 5:40 pm
Today I ordered a 70-200 F4 L and can't wait for it to arrive Big grin Will report back once I've tried it out! Big grin
Religion is an illusion of childhood... Outgrown under proper education.
calfo
RE: Canon 70-200mm
Mon Oct 27, 2008 5:42 pm
Quoting Daleaholic (Reply 10):
Well, I just ordered my 70-200mm F4L IS yesterday!!
Daleaholic
RE: Canon 70-200mm
Mon Oct 27, 2008 8:26 pm
Quoting Calfo (Reply 11):
Brilliant, you'll have to let us know how you get on with yours  Smile
calfo
RE: Canon 70-200mm
Tue Oct 28, 2008 12:20 am
Quoting Daleaholic (Reply 12):
I sure will!
JeffM
RE: Canon 70-200mm
Tue Oct 28, 2008 12:32 am
I'd say the Sigma 70-200 f2.8.
trvyyz
RE: Canon 70-200mm
Tue Oct 28, 2008 3:13 am
I never understood how anetters used F2.8 and to take a/c pics and get the whole a/c in focus.
JohnKrist
Crew
RE: Canon 70-200mm
Tue Oct 28, 2008 5:05 am
Quoting JeffM (Reply 14):
I was going to buy that for my Minolta, but changed my mind after reading several reviews, particularly dpreviews that said this about the Canon one "We can't recommend this lens to anyone".
So I was going to buy a Sony SAL70200G, and that lens was $400 more expensive than the Canon 70-200L 2.8 IS, so I decided to change system and got a 50D as well.
Quoting TRVYYZ (Reply 15):
It's not so hard as the blurring is not that apparent on a longer distance. I have shot aircraft with my 50mm 1.4 that have the entire aircraft in focus.
Airliners.net Crew-Head Support
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
JeffM
RE: Canon 70-200mm
Tue Oct 28, 2008 11:55 am
You need to learn about depth of field and the things that effect it.
Quoting JohnKrist (Reply 16):
Too bad, I've owned one for Nikon and one for Canon and both have been absolutely fantastic lenses. Guess that goes to show you dprieview isn't always right or accurate.
SNATH
RE: Canon 70-200mm
Tue Oct 28, 2008 12:49 pm
Quoting JeffM (Reply 17):
Or maybe Sigma's infamous quality assurance (i.e. lack of) hit again and the dpreview guys got a really bad copy...
Tony
Nikon: we don't want more pixels, we want better pixels.
EMA747
RE: Canon 70-200mm
Tue Oct 28, 2008 1:07 pm
Good point. I remember shooting f4.5 at CDG one time and the pics all came out a bit out of focus in one part or another. Does it depend what angel you are shooting the plane at? If it's a 90 degrees to the plane
Photo © Jonathan Derden - Spot This!
shot I guess it's a lot easier to get it all in focus at f2.8. For a shot like this
Photo © Zaninger Jonathan
where there is a bigger depth of field I guess it's much harder (maybe impossible?) to get it all in focus at f2.8.
Anyone have any examples shot at f2.8 on here?
Andy S
Failing doesn’t make you a failure. Giving up and refusing to try again does!
trvyyz
RE: Canon 70-200mm
Tue Oct 28, 2008 4:39 pm
Well, I was precisely talking about it. Have you taken any full shots of a/c's at F2.8 and if so can you post an example of it?
JohnKrist
Crew
RE: Canon 70-200mm
Tue Oct 28, 2008 7:37 pm
I have a couple I have shot at 1.4 "on the other side", early morning at MMX
One example: photo ID 5971697 at "dark side"
[Edited 2008-10-28 12:42:48]
JeffM
RE: Canon 70-200mm
Tue Oct 28, 2008 9:17 pm
Quoting TRVYYZ (Reply 20):
Hundreds....but I'm not about to dig through them all for this....
Try punching in some info here on your camera/lens/distance...you'll be surprised.
http://www.dofmaster.com/dofjs.html
a 200mm lens at f2.8 at even 500 feet will produce a zone of focus of 213.4 feet. 84.9 infront of the plane of focus and 128.5 behind. Plenty of room, and it increases with distance. A 50mm at 1.8 at 100 feet produces almost that.....99.3 feet.
aviopic
RE: Canon 70-200mm
Tue Oct 28, 2008 10:19 pm
Quoting JeffM (Reply 22):
Haven't you still given up hope they will ever understand Jeff ?
I did, long time ago...........
BTW there is a DOF indicator on top of your lens which will pretty much match the calculations, if you know how to use it that is.
Sigma 70-200 with 2x TC at max focal distance, max zoom and max aperture.
Photo © Willem Honders
I know the pixel peepers will tell it's soft wide open, soft at the long end and unworkable soft with TC........ I've heard it all for years, well if my Canon 24-105/4L had half the optical qualities of the Sigma it would be somewhat worth it's price tag.
Although I have to admit that the latest version with macro added is one step to far.
[Edited 2008-10-28 15:23:11]
The truth lives in one’s mind, it doesn’t really exist
trvyyz
RE: Canon 70-200mm
Wed Oct 29, 2008 12:42 am
Quote: JeffM
That's a cool link. Thanks. We all know we could always learn something from you   Wink
[Edited 2008-10-28 18:04:42]
allpress
RE: Canon 70-200mm
Wed Oct 29, 2008 7:10 am
70-200 2.8 IS...
you wont need to upgrade =]
landing is just a controlled collision with earth
Buyantukhaa
RE: Canon 70-200mm
Wed Oct 29, 2008 11:00 am
Interesting site, thanks for sharing!
I scratch my head, therefore I am.
rovingbroker
RE: Canon 70-200mm
Wed Oct 29, 2008 2:02 pm
Calfo:
I suggest you spend some time with your 70-300 set at 200mm shooting with the IS on and off. Look at the results and decide if for your shooting the IS would be worth the extra $500+.
Then try some careful test shots at 200mm with max aperture (wide open) using a tripod and decide if you can live with the shallow depth of field. I think you'll find that only one portion of the airplane you're shooting will be in focus. If you will only be shooting big airplanes and you don't have any interest in using selective focus to isolate portions of them then paying an extra $650 for the faster lens would be a waste.
But for shooting people or making dramatic, interesting and creative pictures there is no question that the f2.8 IS is the best tool on your list.
michlis
RE: Canon 70-200mm
Thu Oct 30, 2008 11:11 am
All this talk about the 70-200 f/2.8 inspired me to rent a copy. Looking forward to giving it a workout this weekend.
If you know the enemy and know yourself, you need not fear the outcome of a hundred battles.
fergulmcc
RE: Canon 70-200mm
Thu Oct 30, 2008 11:52 am
Quoting Michlis (Reply 28):
You won't look back, attached to my 1Dn all the time, one of the best lenses I've ever bought, enjoy, you won't want to hand it back! Big grin
Have fun
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
michlis
RE: Canon 70-200mm
Mon Nov 03, 2008 12:10 pm
Quoting Fergulmcc (Reply 29):
I know what I want Santa to put in my Christmas stocking this year...actually it would probably be safer under the tree. Awesome lense.  bigthumbsup
