paulmcm
Cheap Teleconverter For Any Camera On Ebay?
Tue Nov 25, 2008 3:56 pm
I was looking on ebay for a teleconverter for my E520 and 70-300mm zuiko lens and i came across this converter.It is dirt cheap and costs about $40 including delivery, compared to the price of the EC20 that olympus makes it cost about $450 including delivery.Here is the link to the item i mentioned.please let me know what you think of it!
http://cgi.ebay.ie/2X-TELECONVERTER-...0257439505&_trksid=p3286.m63.l1177
Olympus E520,Zuiko 70-300mm
Buyantukhaa
RE: Cheap Teleconverter For Any Camera On Ebay?
Tue Nov 25, 2008 4:40 pm
I got two lenses off Ebay for my Olympus C765 "compact" camera, one for 2x and the other 0,45%, costing about EUR60 if I remember correctly.
You get what you pay for. Wide-angle converter wasn't that bad, tele was horrible. I'd say it's a waste of money. Get the expensive converter if you really need it, or get none at all, in my opinion. The Sigmas are slightly cheaper and not too bad I think. Not sure if they're available for Olympus, so check.
I scratch my head, therefore I am.
ANITIX87
Tue Nov 25, 2008 10:14 pm
I would avoid this thing like the plague. It attaches to the FRONT of the lens. It is not a true telephoto converter!!!! Also, it says it will work on ANY 58mm filter lens. That means it will fit on the 14-45 and the 70-300 just as well. But those two lenses have their front lens element in different locations, so I really don't think the camera will like focusing with this thing on there.
I say don't even dare. Go with the real Olympus converter if you really need the range. (Although on the 70-300 it's useless with the aperture. You'd lose autofocus. I would have gotten the 55-200 and then the 2x.)
TIS
NIKV69
Tue Nov 25, 2008 10:51 pm
Quoting Paulmcm (Thread starter):
Quoting ANITIX87 (Reply 2):
This sounds like the guy in non-av who bought a Rolex from a guy on a beach for $10.
Like Antonis told you. Avoid and buy the real thing.
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
oly720man
Tue Nov 25, 2008 10:56 pm
Review here... and it gets 1 star (can you give no stars in Amazon reviews?)
http://www.amazon.com/Bower-Telephot...sion-Digital-Cameras/dp/B000J6647I
The instant I screwed this lens onto my Sony DSC-H2, I lost a ton of resolution. When I zoomed all the way in with the lens on (which wasn't much closer than without), I had no image clarity, even in the center of the image. I tried a tripod and set the timer on my camera, but the image was no better. My friends that I showed the pictures I took with it thought I was using a special-effects lens because they were so unclear. I got much better quality using my built-in optical zoom and digitally zooming closer.
And, as already stated, with the 2x converter that goes between the lens and camera you'll usually lose AF capability unless you've got a high spec main lens - this is because the AF system can't cope with the reduced contrast at the changed aperture, or so I've read.
paulmcm
Wed Nov 26, 2008 9:57 am
Thanks guys.Well i could make do with the 300mm but i just always craved that little bit extra range.I might forget about a converter and closer to the summer buy a second hand sigma 135-400mm or the 500mm version and hopefully a cheap secondhand Olympus E3, and if not just blot it to the E520.That brings me to a another question, is it worth the money to jump from the E520 to the E3?Will it make that much of a difference?
ANITIX87
Wed Nov 26, 2008 1:35 pm
Quoting Paulmcm (Reply 5):
I would have said yes until the E-30 was introduced last week. I would recommend you go to the E-30 unless you really plan on doing professional stuff (sports, dark light, events, etc.). The E-30 has 12MP, which is good for aviation because of the extra room for cropping, and has a similar sensor to the E-3, so the noise performance should be quite good. It also has 11 AF points like the E-3 has so you get the versatility as well.
TIS
paulmcm
Wed Nov 26, 2008 2:00 pm
Well next summer i am going to an A1 world motor sport event and hope to attend a few of the airshows in england and europe, by that time i am hoping there are some cheap secondhand E3's out there.I dont think i would buy the E30 just yet, the jump in capability over the E520 would not be worth the euro1200 cost of the body alone.
ANITIX87, what do you think of the Sigma 125-400mm you have?Have you encountered any problems with it and also do you require any tripods or is it stable enough for handheld shooting!?
Thanks.
ANITIX87
Wed Nov 26, 2008 6:03 pm
Quoting Paulmcm (Reply 7):
It's 135-400, I don't know if that was a typo or if you're thinking of a different lens.
I love it. It's f/4.5-5.6 so at the 800mm equivalent it gives you when zoomed in, it's plenty fast. It's a little bit heavy if you're shooting for extended periods of time, but I'm really not bothered too much by it and it's easy to shoot hand-held for a few shots if you have to. I have recently started using a monopod when I shoot and it helps a bit, too. The only problem I have found with the lens is that it hunts sometimes in AF mode, and for some reason when you are in AF mode the focus ring actually turns when the camera finds its focus. So if your hand is on the ring you block the mechanism, or your hand may slip off as the ring turns. It's also a tiny bit annoying that the lens zooms in in the opposite direction than all Olympus lenses (i.e. you turn the zoom ring CCW instead of CW).
I have attached a link to my website. Go to AVIATION -> ABE/KABE and all of these are taken with the Olympus E-500 and the Sigma 135-400. If you want to see some more recent ones with the E-510 or want to see full-size ones for comparison, I'd be glad to send you a couple, contact me through my profile.
http://www.tisdigital.com
TIS
paulmcm
Fri Nov 28, 2008 6:37 pm
Antixi87, i am unable to private message you, it says i have to be a first class member to do that.I found a 135-400mm on ebay for $370 and i bought it, in Ireland it cost 799euro so i bought it without hesitation.Oh your website does not appear to be functioning correctly i clicked on the different sections and no pictures appeared only a blank page!?
ANITIX87
Fri Nov 28, 2008 9:12 pm
Quoting Paulmcm (Reply 9):
Do you have an ad-blocker on? Or is there a certain Javascript plug-in you're missing?
Good choice on buying the 135-400, it will hopefully please you as much as it pleases me.
TIS
