paulinbna
Is 1 MB Limit On Uploads Too Low
Thu Nov 27, 2008 10:25 pm
Every now and again I get file limit reached warning and I only have a 20D. Is it time to get rid of the 1 MB limit. Some time I am forced to save in a more compressed format so they can be uploaded.
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
Moose135
Thu Nov 27, 2008 10:35 pm
What size are you uploading at? I have a 40D, resize to 1024 wide, save at the highest quality level (12) in PS CS3, and haven't had any issues with the 1MB limit.
RCoulter
Thu Nov 27, 2008 10:39 pm
Quoting Moose135 (Reply 1):
+1 I sometimes upload at 1600px at highest quality and usually come in well under 1mb...
flynavy
Thu Nov 27, 2008 10:42 pm
Quoting Paulinbna (Thread starter):
No.
If it isn't broken, don't fix it.
Change is: one airline, six continents!
Psych
Thu Nov 27, 2008 10:56 pm
The background in the photo makes a massive difference to the file size. Could this be the issue for you Paul when it becomes a problem?
If the photo is of an aircraft against a blank sky you can get away with a large image and the edit will still be way under the limit, whereas if the background is very 'busy' with airport structures etc, then something like 1200 wide can push you over the 1MB limit.
I stick at 1024 for 'security' reasons, so it is never an issue for me - 20D or 40D. But I guess the size limit was imposed by Johan due to technical issues at that time, so it seems to me to be a legitimate question whether this could be reviewed in the light of the brave new world of the rewrite/new servers etc. Once on the site, uploaded photos generally tend to be only half the size of the actual image that you upload - due to the compression applied in the uploading process I assume. But even so, there must still be issues about the size of the database with so many photos stored on the servers - though storage is probably far less of an issue for DM than it was to a lone guy in a university room.
Paul
paulinbna
Thu Nov 27, 2008 11:23 pm
Quoting Psych (Reply 4):
This is when I have a problem cockpit shots are one that I have a problem with.
whappeh
Fri Nov 28, 2008 12:17 am
I do 1060x790 (just to be different) and I occasionally have issues. Out of the 77 I have accepted, I'd say 7 had to be resized smaller or saved at an 11 instead of a 12. I just made a thread on this complaining about the same thing, though.
-Travel now, journey infinitely.
cpd
Fri Nov 28, 2008 1:43 am
I usually upload at 1024 or 1280, and they nearly always come in under 500 or 600kb.
I don't see any problem with the 1mb limit.
Bruce
RE: Is 1 MB Limit On Uploads Too Low
Fri Nov 28, 2008 3:27 am
The 1mb limit shouldnot be a problem. 1024px wide is plenty big enough. I have only came too close to 1mb a couple times. and then I saved it at 11 quality. 11 out of 12 is hardly noticeable at all.
Like cpd said, most turn out to be 500-600k.
spencer
Fri Nov 28, 2008 4:15 pm
You can always save to web instead of just a simple save. That way you can save it at whatever file size you want.
Spencer.
paulinbna
Fri Nov 28, 2008 6:36 pm
Quoting Whappeh (Reply 6):
Out of 10 that I just uploaded two were above the 1 MB limit. They were of General Aviation aircraft that were on a ramp with no sky in the background. Like I said this very rarely happens.
lochgilp
Sun Nov 30, 2008 2:48 am
Well to be difficult i'll vote yes. I upload at 1600px, as my laptop screen is 1600px wide and i shoot for me and i can't be bothered editing an A.net version and a seperate one for myself, and it's easy enough to go over the 1Mb limit with ground shots. Would be nice to not need to drop the quality a notch to get it uploaded on here. If the dimensions limit is 1600px then surely the filesize limit should reflect that?
spencer
Sun Nov 30, 2008 10:58 am
As I said above, just save for web and you'll be able to change the file size, (not the physical size of the image!), to basically whatever you want. Easy. Therefore the 1Mb size limit shouldn't be a problem anymore.
Spencer.
paulinbna
Sun Nov 30, 2008 7:28 pm
Quoting Spencer (Reply 12):
Isn't this the same thing that Save As does. The last option is to pick whether you want to save at 12, 11, 10 and so on.
spencer
Sun Nov 30, 2008 8:11 pm
No as you can't see at what value, in Mb, your image finishes at. I've always saved at 12 anyway, so AFAIK the image gets saved at whatever 12 relates to Mb wise. In save for web you can move a slider from 0-100 which will result in a file size difference. Eg. If 100 gives you an image larger than 1Mb then slide down to say, 95 and see what that gives you instead. Hope it helps.
Spencer.
RCoulter
Sun Nov 30, 2008 8:46 pm
One of the main things with "Save for Web" is you lose the EXIF data, which doesn't matter for this site but it does for others. "Save As" keeps the EXIF which results in the larger size.
spencer
Sun Nov 30, 2008 10:03 pm
Personally I don't save for web unless like the OP said, it becomes a problem with the file size. In reality that's 1% I'd say. As to the EXIF data, I couldn't care less about it.
Spencer.
jensobreuer
Mon Dec 01, 2008 10:35 am
Especially night shots are ofter quite large - even in 1024 or 1280. It would be great if the file size would be increased to 1,5MB
michlis
Mon Dec 01, 2008 3:02 pm
From a business perspective, larger file upload limits = greater storage requirements + more bandwidth which leads to more cost to run the site. While I've had a few uploads where having greater than 1 MB would have been nice, I've found that with proper framing while taking the shot and proper editing afterwards the 1 MB limit can almost always be met.
If you know the enemy and know yourself, you need not fear the outcome of a hundred battles.
