spencer
Scanner Advice Please.
Sat Dec 06, 2008 7:06 pm
Hi all. I'm embarking upon a bit of a mission, going through my old prints from way back when.... The scanner I have now, although it does the trick, needs to be replaced as I'm pretty sure I could get better results with a modern one. (The one I have now is touching 6 years). I'll be using it entirely for scanning prints, not slides. Suggestions please.
Spencer.
wilco737
RE: Scanner Advice Please.
Sat Dec 06, 2008 8:17 pm
Hi Spencer,
I use the EPSON Perfection V500 Photo and I am quite pleased with it. It is easy to use, it can scan negatives as well.
Scan from a print:
Photo © Wilco737
Scan from negative:
Photo © Wilco737
WILCO737 (MD11F)
 airplane
JakTrax
Sun Dec 07, 2008 3:55 pm
I use the Canon Canoscan 4400F and I must say I'm more than happy with it. It is a direct competitor to the scanner mentioned above by WILCO737 and is similarly priced.
Examples of mine in the database:
Photo © Karl Nixon
Photo © Karl Nixon
Photo © Karl Nixon
Photo © Karl Nixon
Photo © Karl Nixon
Photo © Karl Nixon
Karl
spencer
Sun Dec 07, 2008 6:07 pm
Thanks guys. I'd like an honest opinion though here... Below is one of my scans. Quality wise, is it worth getting a newer scanner or is this up to scratch? ie. Will I ever get better than this?
Photo © Spencer Wilmot
Spencer.
paulinbna
Mon Dec 08, 2008 4:34 am
How much post processing is involved in these images, or are these the results after a scan??
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
JakTrax
Mon Dec 08, 2008 11:11 am
Spencer,
Using scanners below £300-400 that is about the best you'll get - no need to upgrade in my opinion. Very nice shot by the way!
Quoting Paulinbna (Reply 4):
Both my examples and Spencer's too have been through processing - raw out of the scanner they actually look pretty awful! Processing for scans is a lot more demanding and takes a lot longer but worth it if you can dig out some golden oldies!
Karl
JakTrax
Mon Dec 08, 2008 11:12 am
One thing I forgot to mention - all my example scans were scanned from prints and not neg's. Neg's will produce slightly better images.
Karl
spencer
Mon Dec 08, 2008 7:49 pm
Thaks guys. And btw the Saudia L1011 was a scan from a print as well.
Spencer.
Users browsing this forum: Yahoo [Bot] and 9 guests
